My68ur8's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by My68ur8trd, Apr 5, 2010.
  1. Jan 9, 2013 at 6:58 AM
    #321
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Really dig the delphi sealed terminal unit.
    Got a direct link?
    I am in need of that for my gauges.
  2. Jan 9, 2013 at 7:22 AM
    #322
    My68ur8trd
    My68ur8trd [OP] Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    http://www.dirtboundoffroad.com/accessories/aux-relay-fuse-panel/
    That is the fuse panel and terminals. (note that the seals that they sent to me did not fit the box and I had to order new ones)
    I used Weatherpack 280 connectors and terminals/seals for the harness
    Justin
  3. Jan 9, 2013 at 8:21 AM
    #323
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    Sweet truck man. Never seen this build before!
  4. Jan 9, 2013 at 8:24 AM
    #324
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Excellent! Saved that to my favorites.
  5. Jan 9, 2013 at 9:58 AM
    #325
    My68ur8trd
    Justin
    Williamsburg, VA
    Thanks its a slow build, so I dont update it too often.
    Time is tight nowadays...:)
    Justin
  6. Jan 13, 2013 at 4:35 PM
    #326
    My68ur8trd
    Justin
    Williamsburg, VA
    made the mount for the fuse box today
    16 ga sheet metal worked out really nice.
    just need to finish it ( round sharp corners etc) and paint it and it can go back in when I have all the other wiring done
    Justin
  7. Jan 13, 2013 at 4:46 PM
    #327
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    :jellydance:
  8. Jan 13, 2013 at 6:05 PM
    #328
    My68ur8trd
    Justin
    Williamsburg, VA
    I have a template and extra steel....
    Justin
  9. Jan 13, 2013 at 6:08 PM
    #329
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Yeah, I have steel left from the one I made for my blue sea. I would like to do what you did, but doubt I will. I am too lazy to rewire everything:facepalm:
  10. Jan 13, 2013 at 6:18 PM
    #330
    My68ur8trd
    Justin
    Williamsburg, VA
    this whole project will take time for me. I wont want to have to rewire in the future (add wires to loom ). I think I am going to go ahead a wire a reverse light circuit in and run the wires to the rear bumper and leave them. Then I can just add the fuse and plug in the lights in the future and be good to go.
    I am going to put a breaker on this as well. just need to come up with one. I might make another one to hold a it as well. I forgot about it when I made the one pictured
    Justin
  11. Jan 17, 2013 at 4:22 PM
    #331
    My68ur8trd
    Justin
    Williamsburg, VA
    Scored this off ebay for 15 bucks. Cooper Bussmann 100 amp breaker.
    Now I need to make a new mounting plate for the fuse box and the breaker.
    Anyone want this other one?
    Justin
  12. Jan 20, 2013 at 5:33 PM
    #332
    My68ur8trd
    Justin
    Williamsburg, VA
    On board air install started today
    150 psi 100% DC VIAIR system.
    I wanted to get the tank and compressor under the bed, and I dont have a spare under there, so there is plenty of room. I dont like the idea of mounting it through the bed, so I decided to build a nice crossmember for it
    all 1" .120 wall tubing
    cross member in the works
    I was originally going to build two cross members like that, but after I got one attached, It was sturdy as hell and I decided to just box around the tank
    All grade 8 hardware.
    It attaches to the frame with 2 1/2" grade 8 bolts ( had to drill two holes) I also cut the little alignment tabs for the factory spare off ( dont need them anyway)
    about 3/8" clearance to the bottom of the bed. I cut the bottom of the feet off as well ( dont need them with the bolts going through the side.
    and a shot with the frame mount
    All iphone pics and its dark out there, so I will try and get some more later,.
    Tomorrow I will make the mound for the compressor ( will be right behind the tank) and I will make a slash guard/skid plate for it. Where it is, it should never contact anything. I can hang on it ( Im 170 lbs but the unsupported side of the tank and it might flex 1/8" of an inch. its not going anywhere
    Ill put up more pics tomorrow when the compressor is mounted
    Justin
  13. Jan 20, 2013 at 5:42 PM
    #333
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
  14. Jan 20, 2013 at 9:00 PM
    #334
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    nice on board air setup
  15. Jan 20, 2013 at 9:21 PM
    #335
    skygear
    skygear                    
    I was looking through your gallery, saw a BLACK truck too? Yours?
  16. Jan 21, 2013 at 5:16 AM
    #336
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    He had an xrunner before the white truck
  17. Jan 21, 2013 at 6:53 AM
    #337
    My68ur8trd
    Justin
    Williamsburg, VA
    My toyota truck history :)
    84 SR5 Xtra Cab 4x4 ( Miss it the most) Marty Mcfly style - Sold in 2002
    99 Tacoma Extended Cab 4x4 - Sold in 2007
    2007 X-runner - Sold in 2010
    and now the 2007 Dcab
    Ive also had a 87 camry, 95 tercel, 96 corolla for DD and the wife drives a 2003 rav4
    Here is it on the X rims :)
    Toyota for life i think
    Justin
  18. Jan 21, 2013 at 9:08 AM
    #338
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    Are you going to make the Shoe Creek trip this weekend??
    G
  19. Jan 21, 2013 at 11:22 AM
    #339
    My68ur8trd
    Justin
    Williamsburg, VA
    I was thinking about it, but found on last week that I will be on my way to Italy for work on Saturday. I wont be back until the 2nd.
    Are you taking your 4runner?
    Shoe creek is somewhere that I really want to go
    Justin
  20. Jan 21, 2013 at 11:26 AM
    #340
    My68ur8trd
    Justin
    Williamsburg, VA
    finished up the OBA mounting today
    Added a mount for the compressor
    and tucked it up on the truck
    I am going to remote mount the air intake for the compressor and build a splash guard around it.
    It hangs down about 1.5" below the frame rails, alot less than the factory spare
    Now to plumb the air lines ( changing to 3/8" line so I have it on order) and to wire it all up and paint the crossmember
    Justin
