Mystery Coolant Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Capt_Jason, Aug 9, 2024.
  1. Aug 9, 2024 at 7:04 PM
    Capt_Jason
    Capt_Jason [OP] Member
    I’ve searched through the forum but haven’t necessarily seen the same issues so figured I would just ask.
    My father in law has a 2011 Tacoma with a coolant leak he’s been chasing for a while now.
    It started out with a leaking coolant by pass hose that was swapped out but he continued to lose coolant.
    He determined that as long as he didn’t use the defroster it wouldn’t lose coolant for a trip or two but then would randomly start losing again.
    He noticed that his passenger floorboard would intermittently be wet so we assumed heater core.
    He bypassed the heater core and drove it today and after a couple hours had to add coolant again.
    there’s no visible signs of leaking and the wet floorboard seems to be totally random.
    he did tell me that he found the ac drain smells like coolant but I have no idea why coolant would be mixing with ac drain line. I’m not familiar with Tacomas at all so any insight would be much appreciated!
  2. Aug 9, 2024 at 7:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What engine does it have? 2.7L I4 or 4.0L V6
  3. Aug 9, 2024 at 7:10 PM
    Capt_Jason
    I’ll have to ask tomorrow but I’m pretty sure it’s the 4.0
  4. Aug 9, 2024 at 7:15 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not really any common coolant leak points on the 4.0, if the heater core is bypassed it can't be going inside in cab. Now the A/C drain could be plugged causing the wet floorboard or there's an external water leak into the cab if it only gets wet when it rains.
    Coolant leaks are typically pretty easy to find on Toyota's if they have the factory pink coolant, it usually leaves a white to light pink stain/crust around whatever is leaking.
    isdjww likes this.
  5. Aug 10, 2024 at 3:00 AM
    Capt_Jason
    I was finially able to ask and he’s got the 2.7L. Not sure how much different it woould be to the v6
  6. Aug 10, 2024 at 4:46 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Pick up a UV dye kit and add some to the coolant next time he has to top off. It is a heck of a lot easier to see the glowing residue, especially from odd angles, than it is to see the accumulated crust of cooked-off coolant. I chased a coolant leak for a long time and when I finally added dye, it jumped right out at me and I couldn't believe I hadn't seen it before.
    If you do a thorough inspection with a UV light and don't find it, the unfortunate answer is that it's probably internal (head gasket or worse).
    Ryguy3684, Capt_Jason[OP] and isdjww like this.
  7. Aug 10, 2024 at 6:22 PM
    TacoTuesday1
    SD CA
    Water on floor is water on floor not coolant leak.
    pressure test it.
  8. Aug 10, 2024 at 6:23 PM
    Capt_Jason
    Thanks for the response! Yea I have brought him my black light today and told him that was the only way he was going to find it. It’s such a big leak that it seems crazy to not be able to find it but it’ll definitely show itself with the dye
  9. Aug 10, 2024 at 6:26 PM
    Capt_Jason
    It was definitely coolant in the floor. You could smell it very strong inside the cab. It was just pressure tested when the coolant by-pass hose was replaced. He’s going to try the dye first and see if he finds that way.
    Ryguy3684 likes this.
  10. Aug 10, 2024 at 6:35 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    As far as I know, the only way coolant gets on the floor is from the heater core. But that might not be the only spot it is leaking from. Check seams between radiator tanks and core, maybe? Look for pink and crusty anywhere there is a hose/connection.
  11. Aug 10, 2024 at 6:39 PM
    Ryguy3684
    Ryguy3684 Well-Known Member
    Virginia
    2024 Tacoma TRD off road
    X2 on the dye test. Let us know what he finds. Has the coolant leaked on the floor boards since he bypassed the heater core?
