Mystery low tire pressure light...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lost Bushman, Jan 1, 2025.
  1. Jan 1, 2025 at 10:58 AM
    Lost Bushman
    Lost Bushman [OP] Member
    Arizona
    2015 TRD Offroad
    2015 DCSB.
    I was coming back from camping and towing my small camper. After exiting the freeway, and sitting at the light at the end of the ramp, I turned left. While turning at about 10-15 mph, the low tire pressure warning light came on, flashed, then went off. I pulled over and checked, and all tires were inflated properly. The light has not done this before, or has come on since. A failing TPMS sensor? I haven't been able to find anything in search that lines up with what I had happen. Any help would be appreciated, thanks!
  2. Jan 1, 2025 at 3:01 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you still have the factory sensors you may have a bad one. They typically last 7-10 years but I've seen some last as long as 14 years.
    I'd drive it and see if it repeats. With something like this you just have to wait until it gets worse. At that age I'd replace the sensors the next time I buy tires. I've bought several sets off of Amazon, cost ranges between $50-$60 for a set of 4. Tire stores will install and program them for you at no cost if you're buying tires. If not buying tires $10-$15 each to install them.
    kidthatsirish likes this.
  3. Jan 1, 2025 at 3:22 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I once had on destroy itself in the wheel. Don't ask how. I had the TPMS light come on so I pulled into the first fuel station I came to and checked all four wheels and they were all okay. When I got home from the trip I took the truck to Discount Tire and they found a sensor in two pieces.
  4. Jan 1, 2025 at 4:07 PM
    RustyOne
    RustyOne New Member
    B.C. Canada
    2018 Tacoma TRD Sport
    You can also try to reset the TPMS as per your owners manual. If that fails probably just going to be a straight up replacement of the sensors.:fingerscrossed:
  5. Jan 2, 2025 at 7:25 AM
    AnotherDude
    AnotherDude Well-Known Member
    Have you checked the pressure of your spare?
  6. Jan 2, 2025 at 10:56 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Just coming to post this….from experience.
    Rocketball and wilcam47 like this.
  7. Jan 2, 2025 at 11:03 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    From what I've read on here, sometime around 2009-2011 Toyota stopped putting them in the spare. My 11 did not have one. Though it mighta helped since my truck's spare came flat from the factory, lol.
    HooDoo_Taco and wilcam47 like this.
  8. Jan 2, 2025 at 11:05 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
    You guys are lucky then. That thing pisses me off every winter. And you can’t delete it from the system, or iit throws fits. :annoyed:
    ridefreak likes this.
  9. Jan 2, 2025 at 12:37 PM
    YF_Ryan
    Kent, WA
    i just ignore the light. It flashes at me every time I start my truck. After a few blocks it stops flashing and is solid on.
    ToxicTwin likes this.
  10. Jan 2, 2025 at 1:12 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Intermittent TPMS lights are a common indication of a failing sensor, especially flashing. If your 2015 still has its original sensors you’ve done better than I. My 2015’s original TPMS sensors starting failing about two years ago. (My RX350’s original sensors lasted over a dozen years.)
  11. Jan 2, 2025 at 1:22 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I just replaced my 2015 TPMS, they went dead last year. The 2015 has only 4 sensors.
  12. Jan 2, 2025 at 3:43 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I feel lucky, I had to replace my sensors at about 14 years ~130K.
  13. Jan 3, 2025 at 6:28 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    ...just did mine at 15 years, just under 200,000. light came on about a month earlier, and i knew i was getting new tires soon, and since have....
    ridefreak[QUOTED] likes this.
  14. Jan 3, 2025 at 6:32 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Rockauto has the Densos for a decent price.
  15. Jan 3, 2025 at 7:23 AM
    WNYTACOMA
    Clarence, New York
    i bought a 5 pack of the oem's for $52 and change, $57, and change with shipping, from ebay, thinking that my spare was also needed, and when getting my new tires last week, they handed me one back, saying that it wasn't, which left me confused, as i swore that topping off my spare when teh others were at, or near, where they should be, in the past turned my light back off more than once.
  16. Jan 3, 2025 at 7:27 AM
    WNYTACOMA
    Clarence, New York
    ...I will say this, if anyone else goes this route, give it a few weeks before you actually need them, as the once proud USPS has become a bungling, unreliable outfit over the last several years or so. ...mune were stuck in rossford (?) Ohio for over a week, and them over shipped past me, had to go back to another hub before me, to then be delivered to my local for delivery. ...after a little research, I found out that this is not an isolated incident....
  17. Jan 3, 2025 at 9:05 AM
    Lost Bushman
    Arizona
    2015 TRD Offroad
    Yeah, I figured that coming up on 10 years old, the sensors might be failing. I only have 109k on the truck though, I was hoping they would live a little longer than that, but I guess they're always sending a pressure signal even when the truck is off? I don't know.... anyway, I appreciate the input from you all. Thanks!
    Jimmyh likes this.
  18. Jan 7, 2025 at 7:12 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I have an early '09 and apparently at least one of mine is failing as my light has been on for a few months.
    My spare doesn't have the TPMS.
    But 16.5 years and 190k+ miles is pretty good for the OE sensors...
