Mystery no crank no start left me stranded for a bit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Clinch Mountain Preacher, Jul 3, 2024.
  1. Jul 3, 2024 at 10:22 AM
    Clinch Mountain Preacher [OP] Serpent handler
    3rd gen AC SR5 4x4
    After nearly half a decade, I can finally say that my 2.7L powered 3rd gen left me stranded finally.
    Was out fishing hours away from home. Got back to shore and got in the truck, turned the key to ignite the motor. Heard 1 single click and the entire car went dead. Starter never tried turning over. Just 1 click and everything goes dead. No crank, no start, no power going to anything.
    Door locks would not work, Tacoma icon screen in the cluster would not turn on when I opened the door. Nothing. No hum when key in the accessory position either. Starter never even tried to turn over the engine. Just 1 audible click.
    Some weird lights stayed on in the dash briefly... 4Lo (truck was in 2wd), CEL, seat belt light...weird
    Popped the hood and disconnected the batt and reconnected it and after some time. Still didn't work.
    Locked the car doors using the key and then unlocked the door and finally the dash lit up. I turned the key to accessories position and left it there while I summoned the courage to try turnung the ignition on.
    Finally worked, drove back to my town with everything working flawlessly... engine running normal, hi beams working just fine, AC working etc.
    This morning I went to head to work and this whole saga repeated itself.
    Eventually got it started and drove straight to Toyota for diagnostic.
    Truck has +/- 100k miles. Bone stock minus the suspension and an aftermarket remote start thats been installed since 2016 and never had issue when used...Battery is less than a year old. No rust or weird repairs, no electrical add ons or accessories whatsoever.
    I will be sure to post here what Toyota says is the problem
  2. Jul 3, 2024 at 10:27 AM
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    Am I reading the story correctly? It didn't really leave you stranded, the issue just delayed your trips?
  3. Jul 3, 2024 at 10:32 AM
    3rd gen AC SR5 4x4
    You're stranded until you're not.
    If the truck doesn't start when you need it to, you're effectively stranded.
    Getting lucky twice out of 200 attempts and not being able to move the vehicle is being stranded.
  4. Jul 3, 2024 at 10:33 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My money is on the aftermarket alarm/install.
  5. Jul 3, 2024 at 10:36 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
  6. Jul 3, 2024 at 10:37 AM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    same here
  7. Jul 3, 2024 at 10:39 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Agreed. A poor wire tap, solder joint, etc probably corroded
  8. Jul 3, 2024 at 10:48 AM
    nevertoomanytacos
    3rd Gen
    Thanks for the reply...
    Phlogiston likes this.
  9. Jul 3, 2024 at 10:48 AM
    3rd gen AC SR5 4x4
    That's what I'm leaning towards also. Just weird since i haven't used the remote start since winter and it hasn't given me any trouble since 2016/17 when it was installed.
    I'm extremely curious to see what Toyota says..I told them to remove the remote start if they wanted/needed. Definitely not a crucial piece of equipment
  10. Jul 3, 2024 at 10:50 AM
    abou824
    Aidan
    Central PA
    Best of luck getting it figured out. Losing confidence in a vehicle sucks - crossing my fingers they can give you a concrete answer.
  11. Jul 3, 2024 at 10:52 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    Nothing's broken until it is.
  12. Jul 3, 2024 at 10:54 AM
    3rd gen AC SR5 4x4
    Same. Been a rock solid vehicle for years.
    It's taken me to and from some sketchy remote areas solo many times.
    I must say that turning the ignition on while crossing my fingers was a thing I did often with my old VWs..but never with a Tacoma
    .til now
  13. Jul 3, 2024 at 10:54 AM
    3rd gen AC SR5 4x4
    100%
  14. Jul 3, 2024 at 11:37 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Could be the battery still, less than a year old guarantees you nothing, other than maybe a pro rated warranty.
    GL
    SigBoy, StayinStock, Pwakchop and 6 others like this.
  15. Jul 3, 2024 at 11:40 AM
    3rd gen AC SR5 4x4
    Bad battery would still try to crank no? And door locks would still function etc from my experience with weak car batts.
    When the truck magically decides to start, it starts without hesitation and I get no dimming of any lights or anything.
    All I get is 1 single click seemingly coming from the starter.
    Would be great if it turns out to be a bad battery
  16. Jul 3, 2024 at 11:42 AM
    661
    661 Well-Known Member
    SoCal
    Curious what remote starter you have?
  17. Jul 3, 2024 at 11:44 AM
    3rd gen AC SR5 4x4
    Older unit from 2016 made by a brand named Orbit. I don't think this brand exists anymore
    I forget the model number. Been on the truck since day 1almost
  18. Jul 3, 2024 at 11:47 AM
    661
    SoCal
    I run the one from N2 designs. If you end up finding that your remote starter is the issue i'd check them out.
    They have a kit that provides keyless entry as well as remote start for a good price.
  19. Jul 3, 2024 at 11:51 AM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Unless corroded terminals, or bad/loose ground a battery wont magically gain enough juice to crank if it was bad. Likely the remote start or ground issue, personally unless factory i would never install an aftermarket starter. Its not worth the risk of it or some crappy crimps leaving me stranded down the road
  20. Jul 3, 2024 at 11:58 AM
    3rd gen AC SR5 4x4
    Batt is fresh and no corrosion anywhere. Grounds seem fine.
    Could a starter or starter solenoid going bad cause an intermittent no crank no start, no juice to anything?
