Mystery no crank no start left me stranded for a bit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Clinch Mountain Preacher, Jul 3, 2024.
  1. Jul 4, 2024 at 10:07 AM
    #41
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not necessarily, my first Tacoma battery didn't even give me a click. It was pushing 10 yrs old and on an ass freezing cold day however. I have power nothing so IDK about that piece..and unlike yours, mine didn't regain any power.
    That said, having the battery load tested is a must. I've seen batteries croak in a year.
  2. Jul 4, 2024 at 10:23 AM
    #42
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Maybe update the thread title & first post @Clinch Mountain Preacher ?
    “My battery brand X went bad after two years.”
    I wouldn’t call it Moby-Dick if it turned out they were actually chasing a shark called Bruce.
    You’re going to need a bigger battery.
  3. Jul 4, 2024 at 10:36 AM
    #43
    Clinch Mountain Preacher [OP] Serpent handler
    3rd gen AC SR5 4x4
    I'm still not believing it's the batt until they do a load test
    I hear they have big scary batteries around Martha's Vineyard tho
    Malvolio[QUOTED] and eurowner like this.
  4. Jul 4, 2024 at 10:40 AM
    #44
    CenCalWheeler
    CenCalWheeler Well-Known Member
    2003 Toyota Tacoma TRD
    None yet
    This does not seem correct to me, I would definitely blame the remote starter (or a loose ground wire). If the battery was bad, it would not have suddenly started working after a little tinkering.
    Greg-tacoma, EubeenHadd and eurowner like this.
  5. Jul 4, 2024 at 10:43 AM
    #45
    3rd gen AC SR5 4x4
    Exactly my thoughts as well
    CenCalWheeler[QUOTED] likes this.
  6. Jul 4, 2024 at 10:44 AM
    #46
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    if it fixes it...then that was the problem whether you believe it or not...
    RIX TUX and Chew like this.
  7. Jul 4, 2024 at 10:44 AM
    #47
    lbhsbz
    lbhsbz Well-Known Member
    when the dealer tests the battery, they're clamping onto the terminal clamps, not the actual battery lugs. If there's a bad connection between the terminals and the battery, it will test bad, even though it's good. The bad connection could also result in the intermittent no-start.
    Or...the battery could be weak too...I've seen plenty of batteries that test bad and still work just fine, or at least good enough.
  8. Jul 4, 2024 at 10:45 AM
    #48
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Depending on where you live 2 years is a bit short for battery life. But it wouldn't be the first time.
    I replace mine every 2 years regardless as it is hot as hell here.
    So I suspect something was draining it if it is indeed the battery.
  9. Jul 4, 2024 at 10:46 AM
    #49
    ABA180
    East Bridgewater MA
    I mean, I am about 90 minutes from the 'Yard so....
    Maybe it's not JUST the battery of course if it turns out, but no doubt load test the beast and at least see what that shows.
  10. Jul 4, 2024 at 10:46 AM
    #50
    3rd gen AC SR5 4x4
    A dead battery coming back to life makes no sense.
    To go from no click no start no door locks no dash lights etc to starting up right away with all accessories working flawlessly is something I've never experienced with a dead/dying car batt before
    auskip07, EubeenHadd and eurowner like this.
  11. Jul 4, 2024 at 10:48 AM
    #51
    ABA180
    East Bridgewater MA
    It doesn't, but anytime I run into a no start issue it's prudent to at least test it.
  12. Jul 4, 2024 at 10:50 AM
    #52
    3rd gen AC SR5 4x4
    Of course it would be sweet if it's actually as simple as a dud battery. Will save me tons of money. OEM alternators and starters are really expensive nowadays
  13. Jul 4, 2024 at 10:54 AM
    #53
    PaulyFromLA
    PaulyFromLA Well-Known Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    that sucks, my 97 still hasnt :p
  14. Jul 4, 2024 at 10:55 AM
    #54
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I’d invest in one of these. I keep one with me for situations just like yours.
  15. Jul 4, 2024 at 10:59 AM
    #55
    eurowner
    eurowner Duke Sky
    Scoty
    That would be a drain in the battery. The OP said it started in his first post.
  16. Jul 4, 2024 at 11:00 AM
    #56
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Given how small, cheap, powerful, long lasting they are, Everyone should have one!
  17. Jul 4, 2024 at 11:02 AM
    #57
    CenCalWheeler
    None yet
    For people that go into remote areas with their vehicles, you need a logical definitive solution. In this case the issue is intermittent, and replacing the battery may "seem" to work for a while, but not really be the solution. Pointing to the battery just seems like a lazy tech saying "works for me, just recommend a new battery to be safe".
    A battery failure is generally not binary (it is progressive), and certainly does not rectify itself with a little tinkering.
    mtip, 12TRDTacoma, auskip07 and 2 others like this.
  18. Jul 4, 2024 at 11:10 AM
    #58
    3rd gen AC SR5 4x4
    Exactly
    That's the part that's confusing me a lot
  19. Jul 4, 2024 at 12:43 PM
    #59
    eurowner
    eurowner Duke Sky
    Scoty
    I worked at an auto-electrical shop for 3+ years. I tested batteries, starting, and charging systems in the vehicle, out of the vehicle, rebuilt starters, gennys, and alternators, built custom harnesses, and troubleshot.
    95% of the time with a vehicle that has an electrical problem, after we removed the aftermarket stuff, and got the vehicle to stock, the problem was associated with the aftermarket stuff.
  20. Jul 4, 2024 at 1:02 PM
    #60
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    perhaps it’s going to be time to change the title
    “2.7 Taco left me stranded finally”
    to
    “(Insert bad part) left me stranded finally”?
    In addition to failing slowly, batteries can go bad very quickly if it’s an internal failure such as a broken plate, but it’s not that. Keep in mind a dead battery or faulty remote starter wouldn’t be the fault of your truck (unless it’s the alternator or charging circuitry). I think others are correct in saying it was probably the remote start or its cables. You didn’t mention the condition of your battery terminals when you disconnected it - were they loose at all? Also check the other ends of the cables, the ground and the positive terminals. Are they firmly bolted in or is there any corrosion on any of them?
