Mystery nut and bolt for tightening the alternator belt. Sherlock Homes this for me please
Discussion in '1st Gen. Tacomas (1995-2004)' started by yourrealdad, Jul 8, 2020.
  1. Jul 8, 2020 at 12:00 PM
    yourrealdad
    yourrealdad [OP] Well-Known Member
    Colorado
    2007 Red Tacoma DCLB TRD Sport 4x4
    So I had to replace my belts and with the alternator I notice I didn't have the nut that secures the little "T" bolt thing that goes through the slide area and is connected to the tension bolt.
    Then I was disconnecting the piezo and I found a random nut lying in the engine bay. I thought it was my lucky day and figured it was the nut for the alternator. Tried it on and it was too big. Slid right over my threads.
    So ordered the nut from Toyota.
    Nut gets here today and it is the same nut that I found. Both are too big, unless I am missing something.
    I feel like that T bolt is a pretty specific part so unless that isn't OEM what gives?
    Thanks
    Bonus points if anyone can tell me the pitch dimensions of their bolt, not the nut.
  2. Jul 8, 2020 at 1:11 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is either a M8x1.25 or M10x1.25 unless someone cobbled something together to get running.
    if I did not just get out of the shower I would go double check.
    Did you lose the nut ?
    How did the belt stay tight ??
    The pivot bolt must have been really cranked
    cruiserguy and Lucifer1 like this.
  3. Jul 8, 2020 at 1:30 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Your local dealer has " Exploded Views " of this for all to see in the parts department . and with the right VIN# you can probably see it on line.
    unless you are the original owner of the truck, it is quite possible someone "cobbled something together" as Wyoming 09 suggested.
    If you go to replace the fasteners be sure they are Grade 8. Toyota will have the correct parts.
    Please Let us know how this turns out:popcorn:
  4. Jul 8, 2020 at 2:33 PM
    Harryhood87
    Harryhood87 Well-Known Member
    Harry
    New England
    2004 Xtra Cab 4x4 Lunar Mist 260k+
    265/75/16, Yak Q towers
    Anyone know the real name of that T bolt/slide thing? I think I need a new one. Mines starting to strip.
    Lucifer1 likes this.
  5. Jul 8, 2020 at 3:49 PM
    yourrealdad
    Colorado
    You were close I think it is "T bolt/slide thingy"
    s92dvr and Lucifer1 like this.
  6. Jul 8, 2020 at 3:56 PM
    tcjacado
    tcjacado Well-Known Member
  7. Jul 8, 2020 at 7:27 PM
    yourrealdad
    Colorado
    So can any one confirm what size their bolt is? Mine is M8x1.25. Both nuts I have including the one from the dealer is M10x1.25.
    I read another thread and two people posted M8x1.25, but they were 2.7 versions. I am 3.4.
  8. Jul 9, 2020 at 2:04 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Logic says it the nut you bought was M10x1.25 and was to big it pretty much has to be M8x1.25
    Did you look up the number ??Parts get picked wrong all the time . My dealer had one former employee out of 10 part numbers the Parts Manager looked up 1 was correct . Got to the point I said don`t let him near my orders
    Toyota is good for not using strange odd sizes .
    I guess I am spoiled by being able to just go to the bolt bin grab what I need .
    Lots of other M8 x1.25 nuts you could borrow and check in the engine compartment .(Left front corner of the intake manifold )
    Then you never know when something odd ball was used to complete the job.
    Possible someone used a 5/16"x18 or 24 bolt in there !!
    Being this is buried under the alternator maybe someone changing an alternator will be able to tell you 100%
    Good luck
  9. Jul 9, 2020 at 8:44 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Take the t-bolt slide thingy off and take it to a hardware store?
    Lucifer1 and tcjacado like this.
  10. Jul 9, 2020 at 7:31 PM
    yourrealdad
    Colorado
    I just used a caliper and a thread pitch measurer (I am sure there is a proper name for it, like t-bolt thingy) so I know it is M8x1.25. I already said that, and I already put a new nut on it, but why are two Toyota nuts for it the wrong size? I just wanted to see what other peoples bolts were to see if there is one size or two that are getting put in there.
  11. Jul 9, 2020 at 7:46 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Could the toyota nut be for the pulley itself? I remember that one being a bit bigger than the tensioner.
  12. Jul 9, 2020 at 8:26 PM
    yourrealdad
    Colorado
    Hmmm I don't think so cause I was able to move everything around.
    I also can't find it on Partsouq so I have no idea what the part number is
  13. Jul 9, 2020 at 8:35 PM
    0xDEADBEEF
    There's also one that locks the whole assembly in place. Maaaaybe?
  14. Jul 10, 2020 at 2:22 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Parts bagged wrong .This happens to often then people picking just go buy the number having no idea what they are getting
    Online Catalogs can be wrong !!
    I have seen errors cost one customer over $100,000.00 in the wrong parts being ordered from a mistake on a website catalog .
    I wish you well tracking down the reason maybe a Trip to your dealer to get things figured out
