Mystery Plug Behind Passenger Head Lamp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jonpow, Jul 21, 2020.
  1. Jul 21, 2020 at 10:00 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What colors and # of the wires on the connector? Electrical diagrams are available here
  2. Jul 21, 2020 at 11:25 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    That is for the low washer fluid sensor.
    No, you cannot just purchase the sensor, install it in the tank, and magically get the warning light. Ask me how I know.
    Well, since you asked.... I bought the sensor and then found out that North American Tacomas don't have the light in
    their dashboards! Awesome eh?
    Anyone want to buy a low washer fluid sensor? o_O:D
    mikesixtysix, Junkhead and Malvolio like this.
  3. Jul 21, 2020 at 11:44 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I would take the TPMS over the useless windshield washer sensor anyday. Thanks canada.
  4. Jul 21, 2020 at 11:52 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    You don’t have TPMS up there? Didn’t know that.
    Junkhead[QUOTED] likes this.
  5. Jul 21, 2020 at 11:57 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Off road and pro comes with the sensors and it tells you the pressure in your dash.
    The rest of models have no tpms at all. Canada does not require tpms on new vehicles. I was surprised as my 2007 archaic ranger came with one.
    shakerhood likes this.
  6. Oct 2, 2024 at 5:39 PM
    Claytonb
    Claytonb Well-Known Member
    Clayton
    2016 TRD Sport
    6” BDS Lift
    Anyone know what that extra wires in the background going into the back of the headlight assembly is?
  7. Oct 2, 2024 at 5:44 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    He has aftermarket headlights.
  8. Oct 2, 2024 at 6:42 PM
    Claytonb
    Clayton
    2016 TRD Sport
    6” BDS Lift
    My stock lights have the same plug with wires in them.
  9. Oct 2, 2024 at 6:51 PM
    BLtheP
    Plano, TX
    Parking lamp, daytime running lamp, ground.
  10. Oct 2, 2024 at 7:33 PM
    Claytonb
    Clayton
    2016 TRD Sport
    6” BDS Lift
    I have H9 and H11 bulbs for high beam low beam
    And some other bulb i haven’t looked at yet for turn signal, all in a plastic housing.
    low beam is DRL and there wouldn’t be one or more ground wires into a plastic housing
    Someone must know what these wires do.
    They appear to go into the housing where from the front looks like a little area where light might reflect back into the headlight reflector.
  11. Oct 2, 2024 at 7:40 PM
    BLtheP
    Plano, TX
    I went and looked at a pic on eBay to jog my memory since I got rid of my stock halogens for OEM LED over 2 years ago. The 3 wires are for DRL, parking lamp, and ground.
    Low beam is not DRL in this vehicle. DRL is the LED L shaped strip on the outer edges of each lamp. DRL is the bright mode, parking lamp is the dim mode that they switch to when headlights are on. This applies to TRD Offroad. TRD Sport, and starting in 2017, TRD Pro. Up until 2020 when LED became an option for OR/Sport and standard on Pro.
    it’s pretty simple to figure out. You have a turn signal bulb, a low beam bulb, high beam bulb, side marker bulb, then the 3 wires. DRL, park, and ground are all the 3 wires can be. The ground wire out of those 3 is simply for the LED DRL/park strip. Every other bulb has its own ground on its own connector. So 5 total grounds to the housing.
    Claytonb[QUOTED] likes this.
  12. Oct 2, 2024 at 9:01 PM
    Claytonb
    Clayton
    2016 TRD Sport
    6” BDS Lift
    That’s awesome, thanks for taking the time and posting the information.
    Now it all makes sense.
    Thank you
    C.
  13. Oct 2, 2024 at 9:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Not a light in the dash, a warning message in the center screen between the gauges.
  14. Oct 2, 2024 at 9:52 PM
    BLtheP
    Plano, TX
    It’s a light on models without the multi-info display, it’s a message on the multi-info models. But vast majority have the multi-info, so I’m probably being pedantic.
    I’m not sure if the non multi-info models will work if you hook up the circuits. I would imagine they do since the light is physically there on the circuit board. I know for sure the multi-info display models do not work in the USA. Been there, tried to do that as a test by jumpering the circuit. I don’t need the warning but it would be nice.
    3JOH22A[QUOTED] likes this.
  15. Oct 3, 2024 at 5:47 AM
    #35
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    you can fit a gallon plus in that washer tank, cant you just check it at the first of the month instead of adding sensors and wires into the equation?
  16. Oct 3, 2024 at 6:10 AM
    #36
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Imagine your driving on a slushy road, you have the defrost blowing hot air at the windshield to keep ice from forming. As your driving, the cars in front of you kick up slush that hits your windshield, that slush melts as it hits the hot glass leaving behind a thick salty film that blocks your view of the road. You have to hit your washer fluid every 2-3 minutes just to be able to see.
    This is what people in the northern states deal with when there is snow on the roads, its common for some people to use up a gallon or more a week.
    Now imagine your a average American car owner, you dont know anything about cars other than turn the key to make it start. Your not going to pop the hood to check for washer fluid every month. Cars are made for the masses, and the masses dont know anything about cars, so car companies put warning lights to tell you something needs attention.
    Saying "cant you just check it at the first of the month" works for people who know even the most basic things about cars, but 95% of the population does not know anything about cars.
    The same thing could be said about oil level lights, TPMS lights, fuel lights, door ajar lights, and the long list of other lights. But time has proven that people need and want those lights to tell them something is not right on their car.
  17. Oct 3, 2024 at 6:19 AM
    #37
    auskip07
    Skip
    Atlanta, Ga
    My god, how did people survive before sensors?
  18. Oct 3, 2024 at 6:35 AM
    #38
    5nahalf
    Erik
    Minnesota
    Well, back then you had 3k mile oil changes, so your fluid levels all got checked every 1-2 months.
    Cars now are setup to go 10k between oil changes, so for the average car owner, opening the hood is a once/twice a year event that a shop does.
    But also, washer fluid level sensors have been around for over 40 years.
