Mystery Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mateo-the-grappler, Mar 18, 2024.
  1. Mar 18, 2024 at 9:21 PM
    Mateo-the-grappler
    Mateo-the-grappler [OP] New Member
    Need help with my 2011, shes got this weird rattle when im coasting above 30MPH but when I get on the gas it stops, some have said the heatshields are to blame but ive checked and they all seem to be pretty solid in place
    https://www.youtube.com/shorts/GL84aRhFITs
    Turn up the volume its a bit hard to hear
  2. Mar 19, 2024 at 7:02 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I cant hear anything but if in front area look at the drivers side (non on pass) cat heat shield the single clamp and 2 bolts often are rusting off or thru.
    Next is exhaust system where cat bolts to midpipe before muffler the spring loaded clamp with a donut can rust out.
