mystery sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by p.bilgewater, Sep 10, 2025 at 6:22 AM.
  1. Sep 10, 2025 at 6:22 AM
    p.bilgewater
    p.bilgewater [OP] Member
    1996 tacoma 2.7 4wd
    hey all. i know the "what's this sound?!?" question is maybe annoying and definitely subjective, but it's worth a shot. '96 2.7L 4wd manual transmission, ~235,000 miles.
    - it's rotational, i hear it most clearly between 25-55mph, it sounds like a low bass-tone whoosh, kind of like an old locomotove engine chugging.
    - there's no change between gears or in neutral
    - no difference when driving in H4
    - my brakes feel fine, pads new within 5000 miles, no intense vibrations like i'd expect from warped rotors
    - it's hard to pinpoint the location but seems like its coming from the center of the vehicle below me.
    any obvious things to look for and rule out? i'm worried that somethings wrong with the transmission, but i haven't encountered that before.
    thanks for the help.
  2. Sep 10, 2025 at 7:54 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    At a stop engine running in N or in gear
    If u press clutch pedal down to floor does sound go away?
  3. Sep 11, 2025 at 6:39 AM
    p.bilgewater
    1996 tacoma 2.7 4wd
    it's rotational and correlated with speed (increased tempo), so there is no sound at a stop. there is no change based on gears/neutral.
    ControlCar likes this.
  4. Sep 11, 2025 at 6:42 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Bent brake backing plate, maybe.
  5. Sep 11, 2025 at 7:47 AM
    Glamisman
    Glamisman Well-Known Member
    Common things to check would be carrier support bearing, slide under the truck and push up and down on the driveshaft and look for excessive play. Next thing is the needle roller bearing in the front diff where the axle shaft ride, East Coast Gear Supply has a replacement bushing for that. I wish I had a better way to diagnose this... you might have to take it to a shop and have them put it on a lift and run it up to speed with someone undernearth it with a stethascope.
    Andy01DblCabTacoma likes this.
  6. Sep 11, 2025 at 1:14 PM
    ControlCar
    Steven
    Sugar Land TX
    our speedo cables are noisy at one end if failing
    one behind instrument cluster(but u said hear whoosh center under)
    one screwed into the tranny (poss(?)
    i like glamisman's cause too
    lots of threads re: carrier bearing failure sounds/symptons too
    IMO your can visually check (like Glasiman stated)
    push up and down on drive shaft......inspect the rubber bush on the CB
    likely will see cracks or missing chunks of rubber
