Mystery stall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taniwha, Aug 5, 2020.
  1. Aug 5, 2020 at 2:47 PM
    Taniwha
    Taniwha [OP] Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    Was at my daughters house last week and went to start my truck to go home and no go. Tried several times to restart. Sometimes it would run for a split second then die. Ran it on the starter to the top of a hill and drifted home. It started when I got home after bouncing up over a curb into the driveway. I thought that was probably my one 'free' start on a failing fuel pump. Ran all over town today, lots of starts and stops, all good. Stopped at my daughters house to feed her dogs and....no go. Waiting for my wife to tow me the last 2 blocks home and it started. Not throwing any codes. Quite hot here, truck was parked in the front with the drivers side in the sun. Any ideas? Not a lot of info to go on.
    TOMB likes this.
  2. Aug 5, 2020 at 2:49 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Forgot to mention, replaced the fuel pump halfway through my story~
  3. Aug 5, 2020 at 2:51 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Anything common about the truck each time it failed to start? Nose up, nose down, temperature, time of day, after a short run, long run? Were you able to confirm no pending codes?
  4. Aug 5, 2020 at 2:51 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    check engine light?
  5. Aug 5, 2020 at 3:20 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Thanks for the reply. No pending codes. 35 degrees C, parked out in the sun flat ground mid afternoon. 20 k start stop run.
  6. Aug 5, 2020 at 3:41 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    This might sound odd but try parking in a different spot outside of your daughter’s house. There’s a sour spot where I have to park at work, right next to a sign, that my truck won’t start until a few tries. It’s under some shade and I usually finish work at night, so no heat stroke. It’s just that one particular spot. I could park another vehicle length forward or back, and my truck will start fine.
  7. Aug 5, 2020 at 3:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does it always crank?
    Or does it fail to crank at times?
    Is your security key light flashing in the Acc. Position?
  8. Aug 5, 2020 at 3:53 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Ya, point taken. No other good explanation for it. Sure glad I spent $540 on a new pump and wasted a day changing it. King of the troubleshooters! Not
  9. Aug 5, 2020 at 3:55 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Always cranks. Didn't look for the security light. Shit timing. I'm going back to work out of town Monday
  10. Aug 5, 2020 at 3:58 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Battery connections tight and tidy? My old battery gave it up on really hot day.
  11. Aug 5, 2020 at 4:38 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Ha! Just did them. The computer wouldn't recognise the sender in the new fuel pump. Took them off for half an hour and cleaned them, then re-installed. Computer says hi to sender and voila, full tank. ( was showing empty with the empty light on). I'm trying to figure out the age of the battery now
  12. Aug 5, 2020 at 5:10 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Just shy of 4 years old. OEM Toyota 84 month battery. Sits at 12.80 volts, charges when running at 13.75
  13. Aug 5, 2020 at 5:13 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    laughs. What? A Bermuda Grass Triangle on that street?
  14. Aug 5, 2020 at 5:29 PM
    Island Cruiser
    Kauai
    Baja
    lol dude seriously, I have no idea why. It’s just that particular spot.
  15. Aug 6, 2020 at 7:57 AM
    Taniwha
    Dave
    Kamloops, B.C.
    Sounds like a job for Rod Serling ;-)
  16. Aug 6, 2020 at 9:53 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    As i started reading I thought 'fuel pump' #1 answer. They can act all sorts of wonky.
    I do remember in the '90s Honda Accords had a notorious main fuse that heat would affect. (park them in the sun and no start,
    it was where you looked first after 7 years) Maybe we have another type that gets old and cantankerous.
  17. Aug 6, 2020 at 12:27 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Ya, I'm just going to live with it for now and try to park it out of the sun. Gotta 1000 km journey in a couple weeks. I'll drive with my fingers crossed ;-)
  18. Aug 6, 2020 at 12:37 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Oooh. I think I'd be trying hard to pin it down and parking in the sun as much as possible before then. Down here we wish in our hand for stuff and it never works out.
  19. Aug 6, 2020 at 5:59 PM
    Taniwha
    Dave
    Kamloops, B.C.
    Hand wishing and some patience and listening carefully to what the universe is trying to tell me. And listening to all the smart folks here on this forum ;-)
  20. Aug 6, 2020 at 6:39 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bad chip key if it wasn’t the fuel pump
