Mystery tire rub
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tommytomtoes, Oct 18, 2018.
  1. Oct 18, 2018 at 7:22 PM
    Tommytomtoes
    Tommytomtoes [OP] Active Member
    Thomas
    2016 trd sport 4x4 Tacoma
    Hello, I have a 2016 TRD sport 4x4. I recently did the body chop hoping it would fix my problem with my front tires rubbing. Unfortunately, it did not fix the issue. It still rubs when when my tires are spinning in mud or rocks and it doesn’t matter if I’m straight or turned. I even put some tape on the suspected spots (front and rear part of the fender flares, upper control arm) and the tape was untouched after doing some off roading. Anyone know what it could be? I have icon coilovers set at about 2 inches in height and 275/70R17 tire size. Hope someone can help!
  2. Oct 18, 2018 at 7:26 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Stock wheel?
  3. Oct 18, 2018 at 7:27 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Is it perhaps the front fender liner? I think that needs to be remolded for your tire size.
  4. Oct 18, 2018 at 7:40 PM
    Tommytomtoes
    Thomas
    I don’t think it’s a backspace or offset issue but they’re Fuel D584 wheels
  5. Oct 18, 2018 at 7:41 PM
    Tommytomtoes
    Thomas
    I might look into that. Even if it’s not that it’ll be ruled out. There’s no sign of rubbing in the area though.
  6. Oct 18, 2018 at 7:46 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    You hear rubbing but you're not seeing any evidence of it? Are you positive it's actually the sound of rubbing and not the traction control you're hearing? Honest question. This truck makes some crazy sounds when it loses traction.
    Stocklocker likes this.
  7. Oct 18, 2018 at 7:55 PM
    Tommytomtoes
    Thomas
    I was thinking that too. The traction control light comes on when it happens. I’ve also heard with Tacomas when the tire hits something in the wheel whale it cause the traction control to kick in. Hmm..
  8. Oct 18, 2018 at 7:57 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Sounds fishy.
    What’s your caster?
    Comatose likes this.
  9. Oct 18, 2018 at 7:59 PM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Traction control will make sounds that sound very similar to rubbing. If your traction light is coming on that's likely what it is.
    Comb likes this.
  10. Oct 18, 2018 at 8:02 PM
    Comatose
    Miguel
    San Diego, CA
    Agreed, just looked at the specs. I dont suspect that you would need to trim your well liner with that size, but thats specifically from a 2nd gen standpoint. Youre on the right track though, keep hunting for the rub if there is one.
  11. Oct 18, 2018 at 8:04 PM
    Comatose
    Miguel
    San Diego, CA
    FTFY
