n/a
Discussion in '1st Gen. Tacomas (1995-2004)' started by joesmith123, Oct 18, 2023.
  1. Nov 29, 2023 at 3:14 PM
    #41
    joesmith123
    joesmith123 [OP] Well-Known Member
    n/a
  2. Nov 29, 2023 at 5:45 PM
    #42
    tacoman2001$
    tacoman2001$ Well-Known Member
    I had the same issue. There is that rubber steering isolated. It's held together with 2 bolts then you can remove the rack without pulling the splines. From there heat and penetrating oil. I used a punch to open up that slot and it slid out. I'd replace that rubber coupler while you're there. Probably causing some steering play.
