n/a
Discussion in '1st Gen. Tacomas (1995-2004)' started by joesmith123, Dec 24, 2023.
  1. Dec 24, 2023 at 1:27 PM
    joesmith123
    joesmith123 [OP] Well-Known Member
    n/a
  2. Dec 24, 2023 at 1:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    And you've driven it since doing this?
    joesmith123[OP] likes this.
  3. Dec 24, 2023 at 1:38 PM
    joesmith123
    n/a
  4. Dec 24, 2023 at 1:39 PM
    MGMDesertTaco
    You or a helper should keep an eye on the reservoir to make sure it doesn't run dry while bleeding the system. Those mighty vacs won't bleed the system very fast, so running the reservoir dry shouldn't be an issue if you're paying attention.
    Some of those mighty vac systems don't seal the best and some resort to having a friend pump the pedal as another opens and closes the bleed screw on the caliper.
    Motive Brake Systems makes a container that holds brake fluid, connects to the reservoir and allows the user to pump up the system to 12-14psi. As you open the bleed screws the motive bleeder will automatically introduce fresh fluid into the reservoir.
    I use a turkey baster to suck the fluid from the master cylinder, then refill the master cylinder and then use the motive to bleed the system starting with the brake caliper furtherest away from the master cylinder and working back towards the front of the vehicle.
  5. Dec 24, 2023 at 1:45 PM
    joesmith123
    n/a
    Andy01DblCabTacoma likes this.
  6. Dec 24, 2023 at 1:48 PM
    MGMDesertTaco
    Turkey baster is just for emptying the reservoir quickly. It might be more cost effective to have a shop bleed the system for you.
  7. Dec 24, 2023 at 1:51 PM
    joesmith123
    n/a
  8. Dec 24, 2023 at 2:36 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Kevins60 and joesmith123[OP] like this.
  9. Dec 24, 2023 at 3:05 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Did you just top off the master with the wrong fluid?
    Have you driven the truck with the PS fluid in the system?
    You really don't want to push the PS fluid through all of your brake components.
  10. Dec 24, 2023 at 4:06 PM
    joesmith123
    n/a
  11. Dec 24, 2023 at 4:10 PM
    joesmith123
    n/a
  12. Dec 24, 2023 at 5:00 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Remove all fluid from the reservoir.
    Then fit a tygon hose to the right rear bleed nipple.
    Force clean fluid in through the cracked bleed nipple until clean fluid fills the reservoir.
    Then with clean fluid ONLY in the res, bleed the other three corners until the fluid flows clean. Bleed the system again after a few thousand (or hundred) miles.
    Petroleum will swell the seals and rubber parts in a brake system. Bad things happen then.
    ace_10 likes this.
  13. Dec 24, 2023 at 5:31 PM
    joesmith123
    n/a
  14. Dec 24, 2023 at 6:07 PM
    BLT2GO
    BLT2GO Well-Known Member
    2011 White Tacoma TRD TX
    I have heard of people taking a new bottle of brake fluid, poking a hole in the seal on the bottle then carefully flipping the bottle upside down onto the reservoir. That way you can start bleeding your brakes and whenever the fluid level is low enough to let air into the bottle, fluid can flow out into the reservoir. When fluid level rises enough to prevent air going into the bottle, the fluid will stop coming out. Obviously you need to make sure not to knock the bottle over or run the bottle and master cylinder dry.
    VTCAL and joesmith123[OP] like this.
  15. Dec 24, 2023 at 6:15 PM
    joesmith123
    n/a
  16. Dec 24, 2023 at 6:23 PM
    VTCAL
    2021 Sport
    No movement of the brake pedal is required to flush the system/
    The master cylinder ports are open when released. Gravity will drain the reservoir if any bleeders are left opened. Gravity bleed is a useful way to fill an empty brake system. Takes time though.
    Get the mineral oil out sooner than later, don't wait for your equipment to show up.
    Paper towels will soak up the fluid if you work at it.
  17. Dec 24, 2023 at 6:28 PM
    joesmith123
    n/a
  18. Dec 24, 2023 at 10:05 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    100% pass on the vacuum tool. Get the Motiv, the adaptor, and make yourself a catch can (1/4 tube to a large water bottle).
    You're doing extra work by "pulling" fluid to each bleeder valve. With the Motiv system, you add a bunch of fluid to the tank, pressurize it to 12-15psi, then crack the bleeder screws and catch the output. You don't have to worry about the MC getting low, cause the motiv pushes into new fluid. You can flush out the whole* system in 10-15 minutes by yourself.
    I say whole* because if you have ABS there is not a great way to bleed that- and you'll be looking at doing a few flushes over the next few weeks to completely remove the PS fluid.
    Honestly- now that I had this setup, my savvy friends with Toyotas swing by to flush their brake systems using my kit. Had a buddy do that last month on their lunch break. If you were in SD I would extend an invite to come over and have at it.
  19. Dec 25, 2023 at 4:02 PM
    joesmith123
    n/a
  20. Dec 25, 2023 at 4:52 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I've been considering one of these kits for some time now, along with the appropriate caps for the 3 different brand vehicles I own.
    https://www.speedibleed.com/
