n/a
Discussion in '1st Gen. Tacomas (1995-2004)' started by joesmith123, Dec 24, 2023.
  1. Dec 25, 2023 at 4:53 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    . I have this Motive system. I have to say I couldn’t get it to work on my kids Acura, but it has a way different cap. Honda’s bleed procedure is funky too if you do it the old fashioned way. I have the Toyota one for my other vehicles bit haven’t used it yet. It should work fine. Can’t wait to try it.
  2. Dec 25, 2023 at 5:00 PM
    joesmith123
    joesmith123 [OP] Well-Known Member
    n/a
    Rupp1 likes this.
  3. Dec 26, 2023 at 1:36 PM
    Rupp1
    NC
    Have the Honda/Acura cap, but no dice. I had to replace the master cylinder, which is why I bought the Motive deal. I just did it the old fashioned way. #2 son working the brake pedal. I will absolutely try again on my Toyotas though.
  4. Dec 31, 2023 at 3:01 PM
    joesmith123
    n/a
  5. Jan 1, 2024 at 7:03 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Joesmith
    I had similar problems
    I HATE bleeding brakes
    Bought hand held pump
    Got fronts done NP
    Rears……kept getting air after 1/2 gal of brake fluid
    Other member here pointed out that there is a bleeder screw on the LSVP
    This was news to me
    This bleeder should be done b4 both rear corners
    GL
    joesmith123[OP] likes this.
  6. Jan 1, 2024 at 7:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's fluid in your cup down at the wheel. How fast are you expecting it to go?
    I have the same exact pressure bleeder at work and it takes 5 minutes for it to drop 5 psi
    Sometimes the bleeder screw can get clogged with rust
  7. Jan 1, 2024 at 7:14 PM
    joesmith123
    n/a
  8. Jan 1, 2024 at 7:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Remember, if you press the brake pedal you're actually blocking the flow of fluid from the reservoir down through the master cyl
    Does anything come out if you do it the old fashioned way with a helper pumping the pedal?
    Check the bleeder and see if it's clogged
  9. Jan 1, 2024 at 7:19 PM
    joesmith123
    n/a
  10. Jan 1, 2024 at 7:20 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Umm did you drain the reservoir dry in that process?
  11. Jan 1, 2024 at 7:22 PM
    joesmith123
    n/a
  12. Jan 1, 2024 at 7:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its not that simple, you never want to run the master cylinder dry.
    Read up on "bench bleeding" and why it's important
  13. Jan 1, 2024 at 7:27 PM
    joesmith123
    n/a
  14. Jan 1, 2024 at 7:29 PM
    joesmith123
    n/a
  15. Jan 2, 2024 at 8:19 AM
    #35
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You have too much going on. Ditch the vacuum. Hook up the Motiv, attach a catch can, crack the bleeder.
    In addition to the bleeder valve at the LSPV, you can disconnect the LSPV arm from the differential side, and use something (string, zip tie, wire tie, etc...) to hold the arm up as high as possible. This will allow the most fluid through the LSPV.
    ace_10, joesmith123[OP] and TRD493 like this.
  16. Jan 2, 2024 at 9:41 AM
    #36
    joesmith123
    n/a
  17. Jan 2, 2024 at 12:26 PM
    #37
    joesmith123
    n/a
  18. Jan 2, 2024 at 1:13 PM
    #38
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Your brakes aren't really something to not have working properly. I would consider replacing the rubber brake lines. Start with the rear line from the LSPV to the rear axle, this will allow you to check that fluid is getting there. Then crack open each hard line where they meet the wheel cylinders, and make sure you're getting fluid there. And finally, the wheel cylinders themselves. They are fairly easy to replace, especially along side a rear brake job. The rear brakes are kinda a pain to do. Or more rather, it can be a pain to get them dialed in. Most folks over tighten them, and then back them off a bit until they aren't too tight.
    Question: Do you set your parking brake?
  19. Jan 2, 2024 at 1:35 PM
    #39
    joesmith123
    n/a
  20. Jan 2, 2024 at 1:51 PM
    #40
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    The rubber rear brake line should be connected under the LSPV and head down to a junction on the axle housing:
    Couldn't find a clear image on my phone, so tried to find something on google...
    But yes, this:
    It also might be the LSPV itself. You can just get one from Rock Auto, no need for OEM on that part.
    If you've done the rear shoes, then replacing the wheel cylinders will be a piece of cake, if it comes to that.
