N-Fab 2005+ Bed Light Bar (Marty McFly style) + KC Lights - Pickup Only - MA
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by MikeyMcFly, Sep 22, 2016.
  1. Sep 22, 2016 at 5:44 PM
    MikeyMcFly
    MikeyMcFly [OP] This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Sold! Thanks!
    outlawtacoma likes this.
  2. Sep 23, 2016 at 10:06 AM
    David Loflin
    David Loflin 2012 Conversion
    David
    Raleigh/Mooresville NC
    2007/12 BSP AC High Country TRD Off Road
    2012 Front End Conversion RuggedT Decals Phillips 921 Led Reverse Lights and 43mm Dome Led Sylvania ZEVO LED Map, and License Plate Lights Silverstar ZXE Headlights and Fog Lights K&N Air and Oil Filter Panavise dash mount and Proclip phone holder Mobil 1 Synthetic 5w-30 Mobil 1 Synthetic 75w-90 diff oil Fumoto Oil Drain Valve Painted Engine Cover Shorty Antenna Partial Debadge and Rebadge High Country Badges from Silverado Secondary Air Filter Removed FJ 6 spoke OEM wheels Mastercraft Courser MXT Tires UWS Toolbox TRD Bislteins-4600s Recall Leafs Realtree Seat Covers Walmart All Weather Mats Rain X Wipers Belkin Multi Charger ran through Console Firestik NGP 3 foot Antenna Black exhaust tip
    man i wish i had the money for this. i just started looking at these. this is a hell of a deal.
  3. Sep 23, 2016 at 10:21 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Thanks.
    I don't want to sell this, but I know I most likely won't use it. That being said, I have zero desire to give it away, either.
  4. Sep 23, 2016 at 11:13 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Adding additional photos:
    Note the slight corrosion on the lamps doesn't affect their usage.
  5. Sep 27, 2016 at 5:59 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  6. Oct 1, 2016 at 12:17 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  7. Oct 6, 2016 at 6:46 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Weekend bump!
    Come pick this up!
  8. Oct 10, 2016 at 2:47 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  9. Oct 14, 2016 at 9:09 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Weekend bump!
  10. Oct 22, 2016 at 10:24 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  11. Oct 28, 2016 at 8:32 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Weekend Bump!
  12. Oct 28, 2016 at 8:54 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Was the bar originally made for a short bed, which is why you needed the custom mounts to fit a long bed?
    Are the custom mounts included?
  13. Oct 28, 2016 at 9:00 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    The bar itself is identical shortbed or longbed. The way the bar mounts to the truck is by using the rail system screws as a point of mounting. Thus you remove the screws holding the rail system up on the front rail and the side rails at the front of the cab and use the longer bolts supplied (as I noted, one screw was damaged, but they're easy enough to find replacements). On the short bed, the rear mounts the same way (utilizing a rail system screw as the mounting point). For an AccessCab the screw is in the wrong location, so N-Fab provided me with a nut to slide into the rail system that had a stud welded to it, and that stud protrudes through the bar and you use a nut to secure it.
    It's basically utilizing the rail system for the rear mounts rather than the screw holes for the rail system. The bed bar was originally made for the Southeast special "T-Force" trucks which were all identical short beds. I had the only setup on a long bed with the mounts they gave me. I still have those to go with the bar.
    tomwil[QUOTED] likes this.
  14. Nov 2, 2016 at 5:23 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  15. Nov 9, 2016 at 9:08 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  16. Nov 20, 2016 at 12:06 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Still available.
  17. Nov 20, 2016 at 2:14 PM
    TreyStewart
    TreyStewart Well-Known Member
    Trey
    Tigerville, South Carolina
    2013 PreRunner
    URD everything, nfab front bumper with 2 LED bars, maxtrax spindle lift, Baja rack
    I would buy if you shipped lol
  18. Nov 20, 2016 at 2:34 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    There is no good way to disassemble it and ship it that is cost effective to both of us.
    TreyStewart[QUOTED] likes this.
  19. Nov 23, 2016 at 9:25 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Up we go.
