N-Fab Nerf Bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigguy78619, Feb 22, 2011.
  1. Feb 22, 2011 at 6:13 PM
    bigguy78619
    bigguy78619 [OP] Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
    can anyone that has them, or has had some experience with them tell me if they are strong enough to use with a Hi-Lift? in case of a flat. Will they support the trucks weight? Thanks!!!
  2. Feb 22, 2011 at 6:15 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    they will not.
    you will need sliders that are attached to the frame, not bolted to the cab like the nerf bars
  3. Feb 22, 2011 at 6:16 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    even if the steps did support the truck(which i doubt) the hangers where they bolt on to will not. you need some pretty strong metal and either be welded or bolted to the frame itself in multiple places to use a hi lift on them
  4. Feb 22, 2011 at 6:25 PM
    bigguy78619
    san diego, ca
    thanks.! im indecisive about the avid or all-pro sliders. I just cant spend that much $$$ right now.
  5. Feb 22, 2011 at 6:40 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    If you are ever consisting using a hi lift or there will be need for one later on just do it right the first time and get sliders. If you look where the nerf bars would attach you can tell that the brackets won't take the trucks weight
  6. Feb 22, 2011 at 6:41 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Definite No .
  7. Feb 22, 2011 at 7:08 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    I have N-fabs for mainly looks and as a step but go sliders for jack points, prevent door dings, and off road protection.
  8. Feb 22, 2011 at 7:14 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Are there frame attached sliders that double as steps aswell?
  9. Feb 22, 2011 at 7:22 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  10. Feb 22, 2011 at 7:29 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    I think his question was asking if they stick out enough to be used as steps. From what I have read here(not actual expirence) the answer is yes they do stick out enough to be used as steps
  11. Feb 23, 2011 at 6:14 AM
    Airun
    Aaron
    Show Me State
    Yeah I agree. But probably some better than others.
