n00b help!!!
Discussion in 'Lighting' started by cgs2k2, Jun 26, 2012.
  1. Jun 26, 2012 at 8:18 AM
    cgs2k2
    cgs2k2 [OP] old man
    I'm wiring up a single 55w auxiliary reverse light with a switch in the cab and could really use you guys' help
    A few questions:
    is 16 gauge wire ok for 1 55w lamp?
    is there a difference between grounding to metal or grounding to the neg battery terminal?
    is a relay necessary?
    Thanks for the help!!!!!
  2. Jun 26, 2012 at 10:15 AM
    Hii
    Hii Well-Known Member
    People are going to talk shit on my answer.
    16 gauge is perfectly fine
    Wiring to the chassis is perfectly fine
    (here comes the shit talking part) a relay is NOT necessary. Positive wire from the light to your switch, then another wire from the switch to your positive battery terminal WITH A FUSE ON IT as close to the battery as possible
  3. Jun 26, 2012 at 10:36 AM
    cgs2k2
    cgs2k2 [OP] old man
    Cool, thanks for the response! I'm not trying to catch my truck on fire.
    What Amp fuse should I use? 5? 55w/12v = 4.9 or so... so I figure 5 should be ok but i'm not positive.
