N2 Design Remote Start/Module doesn’t start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Myerwiener_, Jan 7, 2024.
  1. Jan 7, 2024 at 10:24 AM
    Myerwiener_
    Myerwiener_ [OP] Member
    Oscar
    2020 Tacoma TRD Off-road
    Bilstein 5100 up front with Eibach coils. 5100s rear with Icon mini leaf pack. RRW 17x9 wheels with 265/70/17 Wilpeaks
    Hey everybody this morning I installed N2 Designe remote start and phone module on my 2020 Tacoma with push start key. I started with the remote start itself first and followed directions to include YouTube video from N2 and went to test and worked fine. Was able to start with key fob. So I moved to the phone module. Again followed all instructions plus YouTube video. Went to start via app and was unable to start. I was however able to lock and unlock vehicle. So I decided to try the key fob and now it also won’t start with fob. I tried reprogramming and still nothing. I also completely removed everything and tried again and no luck. I noticed after I try to start wether it’s the key fob or app and go inside the truck my dash start to flash for a few seconds (hazards, fog light and a few other dash lights) and I hear a click that happens maybe 4 times and it stops. Ended up taking the entire kit out and put truck back together and starts just fine and drives. Any advice? Thanks in advance.
  2. Jan 7, 2024 at 11:21 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Give them a call.
    Probably something simple, but if not, they'll take care of you.
    Jakerou and Stuck in VT like this.
  3. Jan 7, 2024 at 11:37 AM
    Myerwiener_
    Oscar
    I tried to call the number that came with kit but seems like they are closed for the day. I’ll give them a call tomorrow.
    DTaco18[QUOTED] likes this.
  4. Jan 8, 2024 at 9:16 PM
    Beeze_Sneeze
    Beeze_Sneeze New Member
    2019 Tacoma TRD Sport
    OME 2.5 Inch Lift Kit w/ Add a leaf Tires and Wheels Sony Head Unit Upgraded Tweeters Tune
    This exact thing happened to me. Did they offer advice on how to fix it?
  5. Jan 9, 2024 at 9:37 AM
    TacoStarv
    TacoStarv Well-Known Member
    New Jersey
    2020 Black Tacoma SR
    which wire did you cut? i had cut the wrong one. i believe its supposed to be the second one from the top down, and its pink
  6. Jan 9, 2024 at 3:20 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Push to start, no need to cut wire. That's H-key only.. push to start is all plug and play.
  7. Jan 9, 2024 at 5:08 PM
    Myerwiener_
    Oscar
    The kit that I bought didn’t have in the instructions to cut any wires everything was completely plug and play. I do believe the kit for the 2020 Tacoma without the SOS button does need some wire cutting but wasn’t the case for me.
  8. Jan 9, 2024 at 5:10 PM
    Myerwiener_
    Oscar
    I called but unfortunately can’t really work on the truck due to work. Friday I have off so was told to call when I had time to go step by step with a tech to help me.
    na8rboy likes this.
  9. May 26, 2024 at 7:43 PM
    RubenD
    RubenD Member
    Ruben
    Miami
    3gen TRD of road
    I’m having the same issues as you. Were you able to get a response from N2 Designs? What was there advice.
  10. Dec 8, 2024 at 8:04 AM
    Taco1004
    Taco1004 Boats Hoes and Fishy Tacos!!
    WestMonster, MD
    ‘20 TRD-S
    Yakima roof basket Yakima bike rack (x2) Yakima snow rack (fishing rods) K&N intake kit K&N throttle module AFE Silver Bullet TB spacer MBRP stainless off-road exhaust SpiderTrax spacers Enkei RPT1’s 18x9-0 offset CBI front bumper CBI Overland Bed Bars TRD Pro front skid TRD Pro shift knob TufSkinz carbon trim everywhere MESO trim kit MESO MOLLE rack MESO Stage 1 Tails MESO side markers Diode Dynamics fogs Kicker tweeters (Subaru) Kicker CS 3-Way 6x9’s Kicker CS 2-Way 6.5’s JL Audio Stealth 10” sub JL Audio 300w amp Eibach 2.0 Pro front coils Eibach rear shocks SuperLift billet 1.5” rear blocks Camburg UCA’s ECGS Mountain Hatch tailgate panel AVS taillight covers AVS slim window visors AVS slim hood visor Morimoto LB and HB LED’s MaxTrax MK2 recovery boards Hi-Lift jack Custom surf fishing mount GTS headlight lenses RIPP coil packs Taco Troopers wrap
    Most likely you have the Toyota Data Connect installed from the factory if you have the SOS button. Even if you don’t pay the subscription fee for it, the software is still in the vehicle. The trucks ECU and N2’s computer are basically fighting it out and not knowing what the other is doing. Call James @N2DesignsInc and he will get you fixed up. They sent me out a new harness that replaces the original one they send with the units, with an additional pigtail that stretches behind passenger kick panel to fix the issue.
