N2 Designs 3rd Gen Tacoma Plug n Play 6-ch Multi-cam + A/V Mirroring, Quad view + DVR Record
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N2DesignsInc, Jun 15, 2019.
  1. Jun 24, 2019 at 12:30 PM
    #41
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Is there an option that is just cameras, mounts, and wires/plugs? I don't particularly care for a unit that maps it to a quad view on my headunit or something that allows me to cycle with steering wheel buttons. I'd rather put my computer science degree to work and transform coffee into code.
  2. Jun 24, 2019 at 12:35 PM
    #42
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    WOW, GREAT JOB OP!!!:thumbsup:
    N2DesignsInc[OP] likes this.
  3. Jun 24, 2019 at 4:02 PM
    #43
    N2DesignsInc
    N2DesignsInc [OP] --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Mirroring for anything you can connect the output of your phone via adapter to RCA, so yes. I think in your case it's "MHL" I believe. Android is less involved than Apple. It's not CarPlay so it's not exclusive to one OS or the other. In short, yes, most definitely!
  4. Jun 24, 2019 at 4:03 PM
    #44
    N2DesignsInc
    Los Angeles, CA
    Yes, there is. Special just for you. PM me.
  5. Jun 24, 2019 at 6:58 PM
    #45
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Maybe a dumb question jimmy. Any chance of selling a kit with just the side view mirror cameras that would turn on when you turn on the left or right blinkers?
    I'm sure this is child's play compared to the setup you're making.
  6. Jun 24, 2019 at 10:12 PM
    #46
    N2DesignsInc
    Los Angeles, CA
    Yup, available now. See post 1 for details (I edited them in). Special order. 7-10 business day turn around. That's the first kit, sold bare, it's everything you need for the blind spot detection, integrates the rear, and gives you 3 more channels PLUS A/V mirroring channel for smart phone mirroring. You get the two side view mirror replacement trim pieces, the two side cameras, and all cabling. All automatically triggered or manually toggled through the steering wheel. Slap a front camera on whenever you want and plug it's RCA into the modules respective "front" channel input and your front camera will come on automatically for 10 seconds when you shift into drive. Your OEM reverse will come on automatically when you shift to Reverse, Left/Right when you signal. All the other channels can be accessed through manually toggling through them via your steering wheel (including the A/V mirroring). I don't have anything that's just 2-channels, you get all the channels whether you use them or not.
    $420, shipped free. No tax outside CA. PM to order.
    Skydvrr likes this.
  7. Jun 25, 2019 at 7:54 PM
    #47
    N2DesignsInc
    Los Angeles, CA
    Here lets slowly help therapeutically bring you back in...a little better??
  8. Jun 25, 2019 at 8:03 PM
    #48
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    All you need now jimmy is to mount the cameras further out on the mirror (like the 2020 Tacoma’s) so you can do Side cam AND MESO puddles!
    SandyTaco4x4 and CAG Gonzo like this.
  9. Jun 25, 2019 at 9:58 PM
    #49
    N2DesignsInc
    Los Angeles, CA
    Post #38, page 2, should've tagged you. I'll call you tomorrow, hows China? And where are my boxes?!?!? Don't make me go to Ali Baba and find "my friend Chang" hahaha.
    I may need to get a sample left/right trim piece from you to mimic the bore, mine are pre-molded, and angling should be left where it's at for field of view purposes (it's as far out as possible) where as I think your puddles are happy with a flush bore and parallel to the floor?
    ERod27 likes this.
  10. Jun 26, 2019 at 10:26 AM
    #50
    JackieMoon510
    JackieMoon510 Member
    2018 Tacoma TRD OFF ROAD
    Minor
    @N2DesignsInc - how big are the modules/boxes? And does the dvr need to be mounted somewhere easily accessible to access footage and as well as overheat issues? And this is awesome u guys r making these mods. Thanks again!
  11. Jun 26, 2019 at 10:54 PM
    #51
    N2DesignsInc
    Los Angeles, CA
    DVR is about 6" x 4" x 1". There will be some suggested mounting locations to yes, allow you access to the SD card. It comes with a 16GB, max is 32GB. However, we personally would suggest purchasing a "WiFi" type SD card to access remotely via smart phone. Something similar to this (doesn't have to specifically be this one):
    Then you can put the box wherever you want!
    JackieMoon510[QUOTED] likes this.
  12. Jun 27, 2019 at 4:58 AM
    #52
    JackieMoon510
    Minor
    @N2DesignsInc thank u for that info. Also is the dvr a one box control all or is there another unit to add? And last ? I already have a rear and front camera. What would the cost be for the side mirror cams/controls to have all 4 cans as well as the screen mirror option with dvr, also if u can quote the same setup without dvr. (I dont need the all 4 view at once option either if that costs extra. Thanks again!)
  13. Jun 27, 2019 at 9:25 AM
    #53
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    Hope you two can make this happen. Puddles and Cam how happy I am.
    Rintho likes this.
  14. Jun 27, 2019 at 7:40 PM
    #54
    N2DesignsInc
    Los Angeles, CA
    Quad View or
    Quad View/DVR is an add on.
    The base unit/smart trigger plug in play unit comes with all versions. It's the basic kit you get for the lowest tier package. This kit only comes with side view cams and trims and mirroring input (not the mirroring interface, you'll have to purchase that separately, but that's not the rocket science part of the set up), as well as all the other extra 4 channels that you can put your front and rear camera on. If you have OEM rear, then there is nothing extra for you to do there, it knows it based on a connector you'll either plug in (if you have OEM rear, or not plug in if you have after market rear). That kit is ready to go, no MESO puddle holes (but you can drill those in until we figure out our collaboration with MESO on that). That kit is $420, shipped. The DVR option is a QuadView/DVR in one, price TBD, not released yet.
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - NO QUAD VIEW/NO DVR ($420 - Available now by special order, 5-7 business day turn around). Does not include any extra cameras aside from left/right. Additional Cameras purchased separately, will be offered.
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - WITH QUAD VIEW/NO DVR (Price TBD, Available late July, No Pre-orders, Special Made to Order, Estimated 7-10 business day turn around). Does not include any extra cameras aside from left/right. Additional Cameras purchased separately, will be offered.
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - WITH QUAD VIEW AND DVR (Price TBD, Available late July, No Pre-orders, Special Made to Order, Estimated 10-14 business day turn around). Does not include any extra cameras aside from left/right. Additional Cameras purchased separately, will be offered.
    - All kits will include trim and left/right blind spot cameras, and rear OEM Reverse Integration.
    - Kits with Quad View, or Quad View/DVR (all-in one) will also include all interface RCA Cables to continue the Plug n Play aspect.
    - Additional cameras (i.e. front, under-body, cargo, trailer, etc. not included), but will be offered.
    Optional Accessories:
    Additional Add-on cameras (i.e. Front grill mount, bullet style, etc...)
    Will discuss with Stew the potential to create an injection molded trim piece that can accommodate both his MESO puddle lights AND left/right camera holes for those who have, or want to get the best of both worlds.
    Required Accessories:
    Adapter Cables required to interface your smart phone to an RCA cable (i.e. For an iphone, you would need a Lightning to HDMI adapter (sold by Apple), male/male HDMI coupler, and HDMI to RCA adapter cable for example). Not included, sold separately, not sold by N2 but we can provide guidance on where to source tested and proven products on say Amazon for example).
    Special Custom Requests:
    During roll out, custom requests will be queued on resource availability to accommodate, but will be queued lower on the list and will add considerable turn around time. Probably easier and faster for you to conquer it yourself if you understand A/V. Lead time would be shorter, and will save you some $$$. Not all requests can or will be granted.
    ETA on release:
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - NO QUAD VIEW/NO DVR - NOW, Special Order. 5-7 Business Days if in stock at local warehouse. $420, shipped free, tax in CA only).
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - WITH QUAD VIEW/NO DVR - Late July, Currently no pre-orders. Built to order upon payment. 7-10 business day turn around.
    - Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - WITH QUAD VIEW AND DVR - Late July, Currently no pre-orders. Built to order upon payment. 10-14 business day turn around.
    The 10-14 day turn around is not just the assembly per order received, it's also putting in some hardware en route to me from other sources and well, I've learned the hard way not to under estimate things in which I can't control. I'd like to lean on the shorter side, but you know...Murphy's Law. Also, the non quad view/DVR kit passed QA, QC, testing and install. It's ready to be ordered, but best not to try to part out, piece out the kit, you should wait on the one you want, because you not only want to do this once, but I'm not stocking separate parts, so for you to change your mind and want an upgrade, you'll end up have spent more, and will wait for the component to come in.
    Rintho likes this.
  15. Jun 27, 2019 at 7:50 PM
    #55
    JackieMoon510
    Minor
    @N2DesignsInc awesome thank you so much for info. I already have a front rear cam setup and i already have the screen mirror devices. I will def wait to get what i want. Im def gonna get some form of this setup.
  16. Jun 27, 2019 at 9:04 PM
    #56
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  17. Jun 30, 2019 at 10:09 AM
    #57
    JackieMoon510
    Minor
    @N2DesignsInc im interested in a custom order. I would like to know the price for this setup without the side mirror cameras and the eta on delivery to NC thank you. Also what forms of payments do u accept?--
    Plug n Play Multi-cam w/ smart phone mirroring via Steering Wheel Control - NO QUAD VIEW/NO DVR($420 - Available now by special order, 5-7 business day turn around). Does not include any extra cameras aside from left/right. Additional Cameras purchased separately, will be offered.
  18. Jun 30, 2019 at 6:47 PM
    #58
    N2DesignsInc
    Los Angeles, CA
    PM sent.
  19. Jun 30, 2019 at 7:18 PM
    #59
    ERod27
    ERod27 Well-Known Member
    Eddie
    2019 TRD OR DCSB
    King 2.5s with Camburg Kinetik UCA Cooper Discoverer AT3 XLT 285/70/R17 17" 4 Runner TRD PRO SEMA wheels TRD PRO skid plate 5.29 Yukon gears Apogee front bumper with Warn EVO Apogee rear bumper with tire carrier
    Sub'd. Waiting for prices on the Quad View w/ DVR.
  20. Jul 1, 2019 at 6:05 AM
    #60
    Kryptonite0106
    Kryptonite0106 Well-Known Member
    2018 TRD Sport access cab
    I would be interested in knowing about this as well, since I currently have Meso's puddle lights. Is it safe to assume we could use a different camera mounted underneath the side mirror portion (instead of the arm of the mirror)? Or I could wait to see what comes out of a collaboration with Meso. Hmm, so many mod decisions...
