N2 Designs Remote Start Engine Cranking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phenyers, Apr 10, 2025.
  1. Apr 10, 2025 at 9:59 AM
    phenyers
    phenyers [OP] Member
    2020 DCSB Off Road MT
    I've had an N2 designs remote start installed in my manual Taco for 5 years with no issues. Now it will crank when attempting to remote start via the app and via the key fob, while starting with the key in the ignition works fine. I am still able to lock/unlock from the app and fob. Communication with N2 has been slow and sporadic so in the meantime asking for any ideas or if someone has also experienced this issue.
  2. Apr 10, 2025 at 10:12 AM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    like it'll crank but not start when you remote start it, but all works properly with the physical key? I bet the OBDII connector isn't plugged in and is just dangling. I took my truck in for an oil change a couple months ago and the tech left mine that way. Plugged it back in, works as it should now.
  3. Apr 10, 2025 at 10:31 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Yeah, sounds like a wiring problem- either in the installation or internal to the module.
  4. Apr 10, 2025 at 2:30 PM
    phenyers
    Man. It was right in front of me the entire time I was troubleshooting the module/it's wiring. Just had the truck in the shop and it was indeed the OBD that had been unplugged. I'm all systems go now, much appreciated
    doublethebass[QUOTED] likes this.
  5. Apr 10, 2025 at 9:24 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    :cheers:
