N2 Designs Remote Start Kits and SR Compatibility and Functionality
Discussion in '3rd Gen. Tacomas (2016-2023)' started by finchmeister08, Jan 22, 2023.
  1. Jan 22, 2023 at 12:41 AM
    finchmeister08
    finchmeister08 [OP] Well-Known Member
    Chase
    Fort Wayne, IN
    2019 Tacoma Access Cab SR 2.7L 4x4
    Looking to pull the trigger on one of these kits. I really just need the keyless entry part function, but I can play with the remote start feature to see how it works.
    I’d like to know what the board thinks of this kit with the SR versions. I thought I could do without the fobs, but I just had an instance where I tried opening the passenger door, and it was locked. Keys in hand, I realized there’s no key hole so I had to walk around the truck in shame. :)
    On a scale of 1-10, I’d like to know the following things:
    Installation difficulty
    Installation hours/minutes
    Basic functionality
    Reliability
    Customer Service
    Also, I believe I found the proper kit:
    https://www.n2designsinc.com/produc...tacoma-plug-play-remote-start-kit-regular-key
    SKU: N2-EO-TOY5-RF-K
    Also, I’ve read the OEM installation thread a few times. What price differences are we looking at here for the kit and labor?
    I’m pretty sure I can install a plug-n-play kit myself, but the dealership would have to install the OEM version for me.
    $399 N2 Design
    $??? OEM
    This brand seems to be the board favorite so any reviews will be helpful. :cheers:
  2. Jan 22, 2023 at 6:22 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    The N2 kit is your best bet. No cutting into OEM wires. I don't have it, but I know others have used it to get keyless entry. The fobs will work from a long distance too, unlike our OEM fobs...
    I installed N2 kits our our vehicles and they've worked well. Customer support is good for installation issues. We have the app and it's nice, but in your case I'd definitely go with the long range fob kit.
    na8rboy likes this.
  3. Jan 22, 2023 at 7:21 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They are an easy install, should only be 20, to 30 min install time.
  4. Nov 19, 2023 at 6:26 PM
    allelopath
    allelopath Active Member
    2023 Toyota Tacoma Trail
    Looking here:
    https://www.n2designsinc.com/produc...tacoma-plug-play-remote-start-kit-smart-key-1
    it says:
    Operation
    • To Start: Press the lock button 3 times on factory key FOB
    • To Stop: Press the lock button 3 more times while engine is on
    • Parking Lights will illuminate
    • Run Time is 15 minutes
    • All doors, and hood must be closed
    Special Notes
    • The engine will turn off when any door is opened
    • All Toyota/Lexus vehicles Push to Start ignition type - engine will shut down if any door, hood or hatch is opened.
    So you can't run the truck with any door open?
  5. Nov 19, 2023 at 6:53 PM
    DTaco18
    SR has key type ignition. Engine does not shutdown when a door is opened with key ignition.
    Keyless ignition. Engine does shutdown.
