N2 Designs Remote Start Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yams, Jan 9, 2023.
  1. Jan 9, 2023 at 4:05 PM
    Yams
    Yams [OP] Well-Known Member
    2020 Black Tacoma SR5
  2. Jan 9, 2023 at 4:14 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    there is a nice youtube video with the install, helps clear things up. Ski
    oconnor likes this.
  3. Jan 9, 2023 at 4:27 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    H key, yes you need to cut. Push to start no cut. What's your question?
    cammerv8 likes this.
  4. Jan 9, 2023 at 4:32 PM
    Yams
    My question was if I had to cut or not. The paper guide isn't really informational.
  5. Jan 9, 2023 at 4:37 PM
    Yams
    Do you have a link by chance?
  6. Jan 9, 2023 at 4:52 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    You don't have to cut the TPMS if you don't want to, but if you don't you will not be able to use your fob to unlock the door when the truck is remote started. You'll have to use the key in the door. If you're willing to live with that, don't cut it.
    (I'm about 95% sure on this)
    na8rboy and Stuck in VT like this.
  7. Jan 9, 2023 at 4:54 PM
    na8rboy
    WI
    I have push to start. No cutting. With H-key you are cutting wire so you can open door, without truck shutting off, insert keys turn to run. Push to start, truck shuts off as soon as you open door. Should be light green wire. Your best bet is call/email N2. Great customer service. Don't want to steer you wrong. That or someone with H-key will chime in.
  8. Jan 9, 2023 at 6:14 PM
    timmy_7x
    timmy_7x Well-Known Member
    EB
    Long Beach, CA
    19 Tacoma SR5
    https://youtu.be/HVzFgUeQ9yE
    i used this video. I just went down the wire loom where i had more room to cut it. My kick wiring panel looked like a mess so i didn't have much room close to the plug to cut and strip it.
  9. Jan 9, 2023 at 6:18 PM
    Yams
    Someone said something about losing tpms after install, is this true?
  10. Jan 9, 2023 at 6:18 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    His website is pretty clear cut on my push to start no cut install took maybe 30 minutes because I screwed up the sequence on the set button had to do it 3 times because I’m an idiot.
    Stuck in VT likes this.
  11. Jan 9, 2023 at 6:19 PM
    Yams
    I have the H Key.
  12. Jan 9, 2023 at 6:21 PM
    MadKatt
    Yea your screwed then always a trade of on after market electronics but at least you can remote start.
    na8rboy likes this.
  13. Jan 9, 2023 at 6:22 PM
    Yams
    So you're saying I lose TPMS entirely to install this kit?
  14. Jan 9, 2023 at 6:24 PM
    na8rboy
    WI
    We all have our moments...lol
    MadKatt[QUOTED] likes this.
  15. Jan 9, 2023 at 6:25 PM
    na8rboy
    WI
    No you don't. States that on their web page.
    oconnor likes this.
  16. Jan 9, 2023 at 6:26 PM
    timmy_7x
    EB
    Long Beach, CA
    19 Tacoma SR5
    not true. still works as it should. installed mine 3 weeks ago and haven't had an issue
    na8rboy likes this.
  17. Jan 9, 2023 at 6:34 PM
    Yams
    I swear some people here provide good info and some just make shit up. :^) Thanks guys.
  18. Jan 9, 2023 at 6:34 PM
    DTaco18
    You do not lose TPMS.
    After you cut the TPMS it routes through a relay contact in the remote start.
    It remains connected 99% of the time.
    When the truck is remote started, it opens the TPMS circuit so that your key fob can unlock the door... For some reason, if the TPMS wire remains connected during the remote start cycle, the doors will not unlock from the fob.
    When I had H-key, I cut the wire.
    Won't be a big deal as long as you consider the following:
    1) Cut the right wire.
    2) Cut only one wire.
    3) Cut it in a spot that allows room to be stripped on the connector side.
    4) Don't pull the wire out of the connector while trying to strip it.
    If you mess up, you can splice in a bit of wire by using 3 wago connectors instead of 2.
  19. Jan 9, 2023 at 6:43 PM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    You do not loose TPMS, you will see that there seems to be a problem with the TPMS when you get in after it has remote started, but as soon as you step on the brake, it clears, and everything works just fine.
    Stuck in VT, Yams[OP] and na8rboy like this.
  20. Jan 9, 2023 at 6:49 PM
    na8rboy
    WI
    I know where your coming from, and your thinking. Scary cutting a wire on my truck, and just leaving it cut.
