N2 Designs Remote Start Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yams, Jan 9, 2023.
  1. Jan 10, 2023 at 1:01 PM
    #41
    Yams
    Yams [OP] Well-Known Member
    2020 Black Tacoma SR5
    Okay. It worked once, tried to remote start it again and no luck. I'm giving up for the day.
  2. Jan 10, 2023 at 1:14 PM
    #42
    Yams
    Everything was connected, only thing I'm slightly worried about is my shit job of splicing the tpms wire.
  3. Jan 10, 2023 at 1:17 PM
    #43
    Yams
    Would it make more sense to pull the pin in the tpms and put another in?
  4. Jan 10, 2023 at 1:36 PM
    #44
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Something doesn't sound right... You need to call Jimmy at N2 to get you straightened out.
    Once you've cut the TPMS wire, even if your connections are bad, your fob should still work to unlock the doors when remote started.
    The result of a bad TPMS connection would be your TPMS light coming on and staying on during driving.
    Unfortunately I think you've got more than a TPMS connector problem.
  5. Jan 10, 2023 at 1:44 PM
    #45
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    My guess it you didn't get it back in thst connector,. Yes, you would have to pull pin in connection to re- pin it properly. What did you do, just stick back in. That's what she said...lol
  6. Jan 10, 2023 at 1:49 PM
    #46
    Yams
    No, it never came out. The wire was from the wago connector that had come out.
  7. Jan 10, 2023 at 1:59 PM
    #47
    na8rboy
    WI
    Ok, miss understood, thought tpms got unpinned from connector
  8. Jan 10, 2023 at 2:01 PM
    #48
    na8rboy
    WI
    You just need to go back through and make sure connections are right and good.
  9. Jan 10, 2023 at 2:09 PM
    #49
    Yams
    Final result is: Truck starts on 3 locks, does not stop unless I press brake pedal, fob does not unlock doors while truck is started.
  10. Jan 10, 2023 at 2:13 PM
    #50
    DTaco18
    That means TPMS is not being interrupted like it needs to be. Maybe you cut the wrong wire...
    na8rboy and Stuck in VT like this.
  11. Jan 10, 2023 at 2:16 PM
    #51
    Yams
    Hahahahahahahahahaha that would be my luck. Farthest left light pink wire, 4 down from the top since it's a 2020.
  12. Jan 10, 2023 at 2:31 PM
    #52
    DTaco18
    Maybe problem is in remote start then, but fob not working is definitely due to TPMS staying connected.
    Stuck in VT likes this.
  13. Jan 10, 2023 at 2:31 PM
    #53
    Yams
    Looks like bad connection. I'll get back in tomorrow.
  14. Jan 10, 2023 at 2:44 PM
    #54
    Yams
    You happen to know if I can pull out the module all the wires are connected to by chance?
  15. Jan 10, 2023 at 3:29 PM
    #55
    DTaco18
    I don't know.
    I don't think it's a bad connection.
    A bad connection would leave TPMS wire disconnected which would make your dash light stay on constant when the truck is on.
    A bad connection would also allow your fob to work, which it's not.
    It's possible that the remote start is not opening the relay contact during remote start. Jimmy from N2 can walk you through troubleshooting over the phone.
  16. Jan 10, 2023 at 3:33 PM
    #56
    Yams
    Ah, well I'm not even sure then. Know anything about repinning this connector? The wire decided to snap and now it's ridiculously short. [​IMG]
  17. Jan 10, 2023 at 3:35 PM
    #57
    DTaco18
    Sorry, never repinned, but honestly I'd just use an insulated butt connector and a short piece of wire to make it longer.
  18. Jan 10, 2023 at 3:43 PM
    #58
    Rob64Taco
    Rob64Taco Well-Known Member
    Robbie
    2019 RedTacoma
    Wheels, grill ,fog lights ,blacked out emblems, hard cover shell
  19. Jan 10, 2023 at 3:43 PM
    #59
    Rob64Taco
    Robbie
    2019 RedTacoma
    Spaghetti
  20. Jan 10, 2023 at 5:25 PM
    #60
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Stop! Call N2. They will help you solve your problem. Quit digging a hole! They will help you! At least one response has been called out as wholly inaccurate. You are getting good info from some, but you can't filter through the noise. N2 will help you. No email, call direct.
    na8rboy, DTaco18 and SunRunner like this.
