N2 designs remote starter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dady83, Oct 16, 2022.
  1. Oct 16, 2022 at 11:22 AM
    Dady83
    Dady83 [OP] Well-Known Member
    2020 Tacoma SR5
    I just installed today on my tacoma sr5 2020 the N2 designs remote starter, works fine but I have to press the lock bottom 4 times instead of 3, any thoughts?? Thanks in advance
  2. Oct 16, 2022 at 11:33 AM
    twtaco$
    twtaco$ Well-Known Member
    Lock it and walk away then try 3 times. As if you had it locked all night and then wanted to start it in the morning
    Dady83[OP] likes this.
  3. Oct 16, 2022 at 11:45 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    My Tacoma is NOT N2 (I wish I would have rather than overpay dealer, but my fault) and my GF’s is an N2,,, but both you have to pause a second in between clicks, if you go real quick back to back, one of those clicks doesn’t count.
    Try that
    Dady83[QUOTED][OP] likes this.
  4. Oct 16, 2022 at 11:53 AM
    Dady83
    2020 Tacoma SR5
    Tried it and the same
  5. Oct 16, 2022 at 12:02 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I wasn't aware that SR5 models had that feature enabled?
  6. Oct 16, 2022 at 12:06 PM
    Dady83
    2020 Tacoma SR5
    Yes sir, N2 designs makes them for every trim
  7. Oct 16, 2022 at 12:08 PM
    Borracho Loco
    DFW, Texas
    Ooooooooh! This a 3party aftermarket added accessory. My comment was that Toyota does not put this feature on that model. You're having problems with the aftermarket module.
    My suggestion: Call them up and ask them for technical support. It's their product.
  8. Oct 16, 2022 at 12:10 PM
    Dady83
    2020 Tacoma SR5
    No issues, or I don't know if call it an issue, it's working fine but instead of 3 clicks works with 4
  9. Oct 16, 2022 at 12:16 PM
    timmy_7x
    timmy_7x Well-Known Member
    EB
    Long Beach, CA
    19 Tacoma SR5
    Maybe there’s a way to program it to 3 presses? Just a thought
    chance you can post the model number it link to the starter. Have an sr5 as well and thinking of getting it. Thanks
  10. Oct 16, 2022 at 12:19 PM
    twtaco$
    The control box could be programmed that way I reprogrammed mine for lock unlock lock cranks mine but you need a programmer to do it. Yours could be programmed for 4 instead of 3 can’t remember if 4 was a option though
    I cranked mine a lot with the 3 in my pocket 4 could work better for accidental cranks
    Dady83[OP] and timmy_7x like this.
  11. Oct 16, 2022 at 12:19 PM
    Dady83
    2020 Tacoma SR5
    timmy_7x[QUOTED] likes this.
  12. Oct 16, 2022 at 12:24 PM
    twtaco$
  13. Oct 16, 2022 at 12:25 PM
    twtaco$
  14. Oct 16, 2022 at 5:06 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Cadence is important 1 and 2 and 3. My will take 4 taps if the timing is off.
    Call Justin at N2 he is more than helpful and very patient. Real good guy.
    venezian and Chew like this.
  15. Oct 16, 2022 at 5:14 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Could always go back and reset it then set it again. As was said above when I set mine cadence was important took me 3 times to get mine set right.
  16. Oct 22, 2022 at 10:49 AM
    blapple
    blapple Member
    Ian
    PA
    22 dcsb sr 4x4 v6
    Anyone available to help w install, followed directions to a tee but module keeps throwing solid blue and red flash 3x
  17. Oct 22, 2022 at 2:11 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Send Jimmy a PM and he will help you out. He is awesome with problem solving and his customer service is second to none!
    Stuck in VT likes this.
  18. Oct 22, 2022 at 5:14 PM
    blapple
    blapple Member
    Ian
    PA
    22 dcsb sr 4x4 v6
    Yea sadly just isn’t open saturday
  19. Oct 23, 2022 at 1:50 AM
    VaToy
    Parts Unknown
    PM him, he just mih=ght help you out over the weekend.
  20. Oct 23, 2022 at 2:26 PM
    kaptainsims
    kaptainsims Well-Known Member
    Sims
    2021 Tacoma TRD Offroad Double Cab 6 speed
    None yet
    Anyone have it on a manual taco? I see they sell it
