Nail in my tire question
Discussion in 'Wheels & Tires' started by Superdavert, May 6, 2013.
  1. May 6, 2013 at 10:16 AM
    Superdavert
    Superdavert [OP] Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    While I was changing the brake pads last week, I noticed a nail in my tire. I'll just fix it. No problem. But as these are my first set of A/T tires I have a question. This nail is in between two lugs in the middle of the tire. Sticking out as high as the tread. Now, would a simple plug and go be ok? Or, a patch nessasary? I have road hazard on them, but I would like to be informed.
    Thanks in adavance
  2. May 6, 2013 at 10:17 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A plug should be sufficient. A patch plug would be the best.
  3. May 6, 2013 at 10:22 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Would help if you post the pic...:confused:
  4. May 6, 2013 at 10:25 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Any big tire shop is gonna do both. Plug and patch i had one fixed at discount tire and they said they do both. Sure sucks to get a nail in new tires but shouldnt be an issue.
  5. May 6, 2013 at 10:31 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    No pictures needed.
    I'd get it patched, if not plug/patch. Patch is the standard at any rate.
  6. May 6, 2013 at 10:50 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Like everyone else, patch is preferred plug will work in a pinch. If you have coverage get it done right and not worry about it again.
  7. May 6, 2013 at 11:08 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Plug will be OK by itself if:
    as described, it is in the middle of tire
    air up the tire really high
    install plug but first scour the hell out of the hole with the reamer,
    really lay on it, and air will be hissing out...
    goop up and jam the plug in and leave a little tread-size tail out
    air up tire again, let sit for an hour, test tire pressure, go driving
    check tire pressure again, then next day, then next day
    no leaks after some days, done. no worries.
    if this is on the front, it is a good time to rotate fronts to back. it is a little
    safer to run a 'test tire, one with a new plug' on the back until you know
    for sure leak is sealed.
  8. May 6, 2013 at 11:10 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    gummy worm...
  9. May 6, 2013 at 11:23 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Any hole in the tire, you want to get it plugged and patched. (and that's if the hole isn't too big, or in the shoulder/sidewall) The plug keeps dirt/water out, and patch keeps air in and helps maintain structural integrity of the tire.
    I know Discount Tire repairs tires for free and uses the plug and patch method... don't know if there is one nearby for you..http://dt.know-where.com/DiscountTi...egion=&place=athens,+ga&mapx=&mapy=&x=39&y=12 but any shop that uses the plug and patch method should be fine
