Nail In One Tire, Replace Two?
Discussion in 'Wheels & Tires' started by dsrtne1, Jan 14, 2015.
  1. Jan 15, 2015 at 8:39 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    I agree with plug if it's fixable. Problem is, you don't know which direction the nail is pointed on the inside of the tire and if it has compromised the side wall without dismounting the tire as stated above.
  2. Jan 15, 2015 at 10:48 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Again it's easy. Take tire to shop that does patch plugs. Not just plugs or just patches. They are the best way to fix a puncture in your tire. Here is a picture of a patch plug. It combines both in one. If the side wall is bad then get a new tire.
  3. Jan 15, 2015 at 11:15 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This is true, and it's the proper way, a plug patch is considered permanent tire repair. Find a reputable shop to do it if you can. There is a process to it, utilizing a stitching tool and with vulcanizing liquid compound, etc.
    Good luck!
  4. Jan 17, 2015 at 12:48 AM
    dsrtne1
    dsrtne1 [OP] Well-Known Member
    Michael
    Southern CA
    2013 DCLB TRD Sport
    King 2.5" Coilovers, Total Chaos UCAs, Maxtrac Spindles, 2.5" King Rear Shocks with Compression Adjusters, Wheelers 1.5" AAL, 18" Magnaflow muffler, 30" LED Lightbar, Ultragauge, Tinted Windows
    I went by the tire shop by my work that originally mounted and balanced these tires when I first got the tires and rims and they're willing to plug or patch it. He said he would rather not do a plug patch and actually prefers just a plug or just a patch but will do the plug patch if i really want it. At this point, I just want it fixed. So now the question is, plug or patch? Seems like the general consensus is a plug.
  5. Jan 17, 2015 at 4:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    PLUG PLUG PLUG!
    A patch usually won't work that close to the sidewall. Any flex in sidewall will cause the patch to open up and fail.
    I've had vehicles with a lot of plugs in them over the 4 tires over 5 years. They worked so well, that I honestly don't remember which tires were plugged. If its done right....it'll last until you buy the next set of tires.
  6. Jan 17, 2015 at 6:53 AM
    Crom
    Nick
    San Diego, CA
    Millions
    It is highly unusual for a tire shop to let the customer decide on which repair to do.
    Make them look at it from the inside. Watch this video!
    Tire Safety Starts with Proper Tire Repair:
    http://youtu.be/mdTAalpkSLM
  7. Jan 17, 2015 at 8:15 AM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    I give up. Good luck. Maybe just take it to a tire place that uses chewing gun...
  8. Jan 22, 2015 at 5:19 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    All four tires on my truck have at least one plug. Passenger front has three, I believe. I never have any problems. As long as you plug them right, they'll be just fine.
  9. Jan 22, 2015 at 5:40 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Pull it out, does it leak? Yes, plug it.
  10. Jan 22, 2015 at 5:51 PM
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Had a nail in the exact same spot as yours but in the rear driver side, plugged it no problems.
  11. Jan 22, 2015 at 6:09 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't be.
    Plugged tires, done right, are rock solid. I've autoxd w/up to 3 plugs in one tire and no issues. I promise I got them a lot hotter than a street or trail truck would. Pyrometer after every run was the order of the day.
    I recently plugged one on a Scion right on the corner (but in the tread, not the sidewall) that I was concerned about. It's held for several thousand miles at local and extended interstate speeds.
    Many big box tire shops will no longer plug, because they have too many fraidy cat lawyers. Independent shops will usually still plug. And you can buy plug kits and DIY. Great for the tool kit. When you are out on the trail, you need to be self sufficient.
  12. Jan 22, 2015 at 6:14 PM
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    had my truck in the shop last year for an oil change and so i decided to inspect my truck while the mechanic worked away on it. found a screw in my front passenger tire, the screw head had worn entirely out so it was just the screw in the tire. mechanic pulled it and plugged it. i havnt had a problem at all. just winter tires
