nail in tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by QChawks, Oct 30, 2016.
  1. Oct 30, 2016 at 7:13 PM
    QChawks
    QChawks [OP] Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    its on the inner sidewall so I'm sure it won't be able to be patched either. Now that it's cooling off I have to top off the tire every 3-4 days or the light comes on the dash. I first noticed it rotating my tires a couple months ago.
    The tires only have 20k miles on them too.
    I have the exact stock Dueler tire on the spare so I was thinking of just having them switched out.
    However, does anyone know if the spare on an 09 has the tmps sensor?
    Also, would filling with a can of run flat crap seal around the nail or is that just a bad idea?
    I hate dropping another $200 for one tire.
  2. Oct 30, 2016 at 7:19 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Use that flat tire as a reason to do a lift icons and 285's just my advice.
    Dalandser likes this.
  3. Oct 30, 2016 at 7:22 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Your spare tire should have TPMS.
    If it's not in the middle section of tread, industry standard would tell most shops to not patch, although you could certainly try, some people have luck with plugs outside of that area and in the sidewall.
    Could always try a patch then pony up for new tire if it doesn't hold air.
  4. Oct 30, 2016 at 7:44 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Just use the spare as your new tire. Get a used tire for a few bucks and put it on the spare wheel.
    QChawks[OP] and Clearwater Bill like this.
  5. Oct 30, 2016 at 7:50 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    I like it. There's a used tire shop in town I've used a few times over the years.
  6. Oct 30, 2016 at 7:54 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My 09 spare does not have a TPMS sensor
  7. Oct 30, 2016 at 7:54 PM
    LOLLY
    LOLLY Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    Putting slime in the tire might gunk up and damage the sensor
