name of part
Discussion in '1st Gen. Tacomas (1995-2004)' started by GA1044, Jul 14, 2011.
  1. Jul 14, 2011 at 9:05 PM
    GA1044
    GA1044 [OP] Well-Known Member
    San Marcos, TX
    2002 trd 4x4
    Air Hog, Grey-Wire Mod, Fabtech Coilover 3.5 Lift, Deck Plate Mod, Rear Diff Breather Mod, Magnaflow Exhaust
    Just wanted to know if anyone know whats the name of the part that the front bumper bracket is bolted on to is called? its also bolted on to the frame.
  2. Jul 14, 2011 at 9:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are you talking about the front skid mounting brace that runs between the frame rails, below the radiator?
  3. Jul 14, 2011 at 9:26 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Are you talking about part 16/17 in this pic?
  4. Jul 14, 2011 at 9:36 PM
    GA1044
    San Marcos, TX
    2002 trd 4x4
    @dig-yes thats the part i am talking about
    @Kmok-not those
  5. Jul 14, 2011 at 9:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    #4 in Kmok's parts picture? Don't know its "toyota" name, I call it the front skid mounting bracket.
  6. Jul 14, 2011 at 9:50 PM
    GA1044
    San Marcos, TX
    2002 trd 4x4
    think its part 51021B so guess i will go with that for now, its called a Crossmember Auxiliary, so i will see where i can get one
  7. Jul 14, 2011 at 9:54 PM
    kmok
    Kyle
    Columbus, Ohio
    I might have one lying in my garage...
