Name this sound?
Discussion in '1st Gen. Tacomas (1995-2004)' started by donniele74, Dec 6, 2010.
  1. Dec 6, 2010 at 5:59 PM
    donniele74
    donniele74 [OP] Member
    This sound is coming from my 1997 tacoma, at 19sec i push the clutch in just a little and the sound is gone once i let the clutch back out you hear it again.
    What gives?
  2. Dec 7, 2010 at 12:06 AM
    JDBECK23
    JDBECK23 Well-Known Member
    Jesse
    King George, Va
    '01 Tacoma Reg Cab 4 cyl 4x4
    I cant quite hear what you're talking about... I hear a slight ticking/squeaking sound near the end of the clip... is that what you mean? Could be one of your clutch bearings wearing a little... Doesnt sound that bad though.
  3. Dec 7, 2010 at 4:03 AM
    donniele74
    Yes it is at the very end of the clip the squeaking goes away when i push the clutch in my clutch works fine though.
    The clutch pedal has it's moments where it sounds like a old bed spring when i push it in and out this comes and goes for some strange reason but i am more worried about the motor sound than anything.
  4. Dec 7, 2010 at 4:14 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    sounds like you may have a loose/worn or getting ready to fail throw out bearing &/or fingers on pressure plate starting to wear...
  5. Dec 7, 2010 at 5:25 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    *seconds motion*
  6. Dec 7, 2010 at 3:51 PM
    donniele74
    Thanks for the help guys.
    Now heres the next sound clip. This is me pushing the clutch in and out. It sounds like a old spring it does not do this all the time someday's its competly quit. I know there is a plastic type bushing there that can cause this but if that where the case it would not comes and go would it? :confused:
    I had it at my local dealer ship a few months ago and of course it didn't do the sound at the time and they said there was nothing wrong with it.
    Thanks again
  7. Dec 8, 2010 at 12:19 AM
    JDBECK23
    Jesse
    King George, Va
    Sounds like it could definitely be the clutch pedal bushing in the second clip. Where is the recording device being placed in relation to the truck? Inside, outside, engine bay?
  8. Dec 8, 2010 at 4:02 AM
    donniele74
    Inside the truck right under the steering wheel. If it where a bushing why does it come and go?
  9. Dec 8, 2010 at 5:35 PM
    Avsguy33
    Avsguy33 Well-Known Member
    I have the same issue with mine. I believe it is the T/O going out. It is sporatic but getting more and more constant as time goes on. Ill probably just swap it and a new clutch out next spring sometime.
  10. Dec 11, 2010 at 10:08 AM
    donniele74
    I'm going to take it to get it fixed this week. I had it there a few months ago and of course it did not do it for them. It comes and goes.
    Dumb question if they replace the clutch does the transmission Oil get changed with it?
  11. Dec 12, 2010 at 8:48 AM
    donniele74
  12. Dec 13, 2010 at 3:29 PM
    donniele74
    ok must really be a dumb question.
  13. Dec 13, 2010 at 5:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Generally you don't need to change tranny lube in manual trans, but surely check it for correct level & take note of color of fluid. But if you can afford it go ahead & change it with OEM recommendations....
