Namyo's Truck
Discussion in '2nd Gen. Builds (2005-2015)' started by Namyo, Apr 28, 2010.
  1. Feb 29, 2012 at 2:16 PM
    #481
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  2. Feb 29, 2012 at 4:31 PM
    #482
    Namyo
    Namyo [OP] -
    :cool: this old pic...ante it:confused:
    :goingcrazy:
  3. Feb 29, 2012 at 4:34 PM
    #483
    XXXX
    sKiP
    05 Prius
    Early fall when I totally rebuilt mine.
    If your cam sleeves aren't fused to the bushings and we don't have to mess with them I could swap your BJ's out on the truck in less then 1/2 hr (not including time to remove any other stuff and freeze the new BJ's).
  4. Feb 29, 2012 at 5:01 PM
    #484
    Namyo
    Namyo [OP] -
    Yea I want to at least do the BJ's on them and the tie rod BJ's....may just let the tabs and bushings ride :eek: would like to do the bearings just because the miles on the truck but their not squealing or nuthing.
  5. Feb 29, 2012 at 5:31 PM
    #485
    jandrews
    '09 FourDubDee TRD OR
    I'd wait on the wheel bearings til they give you a signal. You'll get a pronounced vibe or noise well before they fail. No reason with them to spend the money til you need to.
  6. Feb 29, 2012 at 5:36 PM
    #486
    Namyo
    Namyo [OP] -
    :thumbsup: never worried bout any of this stuff on mah 97 taco...drove the piss out of that well over 200k...southern UT desert, Northern salt covered roads, and OBX beach for years! Then I come here, start to wheel harder, and learn about all these mods and perfect fuking trucks and there perfect fucking flex and fuck it all fuk fuk :laugh:
  7. Feb 29, 2012 at 5:40 PM
    #487
    jandrews
    My Corolla is at 189k and change, original wheel bearings with no signs of trouble whatsoever.
    'Course, it ain't modified.
    That said, you'll get some sign. If you wanna be on the super safe side, jack up the truck and check for wheel play each time you oil change. Overkill, but some people like maintenance that way :D
  8. Feb 29, 2012 at 5:45 PM
    #488
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I needs bearings...but they arent making noise :notsure:
    Just wheel play like a mug. Joe Joe, surprised you haven't had any issues yet. Guess they built them right in '05
  9. Feb 29, 2012 at 5:47 PM
    #489
    jandrews
    Vibes?
  10. Feb 29, 2012 at 5:52 PM
    #490
    XXXX
    sKiP
    05 Prius
    yep. Mine "wobbled" loud for months before I changed them.
    Keep an eye on spindle temp with your hand. If it gets hot under normal driving conditions it could be time to do it.
    I pushed all my shit until it was the end then swapped it all at once so it would be quicker. I also stock piled parts well before hand because I knew I would need them eventually. Parts seem cheaper if you spread buying them out over time :D
  11. Feb 29, 2012 at 6:13 PM
    #491
    Namyo
    Namyo [OP] -
    Good ideas there to check and buy parts :) I don't have any vibes or squeal while driving but probably some play in the wheel and dry sounding BJ's. Feels a little sloppy sometimes...think I'll start with the BJ's and UCA's.
  12. Feb 29, 2012 at 6:17 PM
    #492
    jandrews
    Yeah, definitely the place to start. Get the suspension tight and work from there.
  13. Feb 29, 2012 at 6:30 PM
    #493
    XXXX
    sKiP
    05 Prius
    they are already cracked right?
    If they are just get a needle fitting for your grease gun and fill them until they shoot out clean grease through the crack. Then keep up on them until your ready - that's what I did.
    Just don't push them so far that your BJ pops off....that could get bad :D
    keep an eye on the play
  14. Feb 29, 2012 at 6:47 PM
    #494
    Namyo
    Namyo [OP] -
    :thumbsup:
    Cracked I dono..
    I'll haveta get sum grease in there...hate a dry BJ :p
  15. Mar 1, 2012 at 4:31 AM
    #495
    XXXX
    sKiP
    05 Prius
    boot looks cracked to me. get a needle tip and get some shit in there. it will just squirt out but better then nothing.
  16. Mar 10, 2012 at 9:26 PM
    #496
    Namyo
    Namyo [OP] -
    Mah ball joints strong like bull :cool:
  17. Mar 10, 2012 at 9:38 PM
    #497
    Namyo
    Namyo [OP] -
    Few more thousand clearcoats waiting to dry..
    dez bright as a mug :cool:
  18. Mar 11, 2012 at 7:43 PM
    #498
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    :smack: Joao no post pic after wet sand in da sun!!!!!
  19. Mar 12, 2012 at 5:11 AM
    #499
    Namyo
    Namyo [OP] -
  20. Mar 19, 2012 at 12:53 PM
    #500
    Namyo
    Namyo [OP] -
    who knew that ur not supposed to double cross over signal :notsure: for some reason it sounds a ton better now! Letting the cross overs do the work while flat signal goes to them...
