Nanoskin products
Discussion in 'Detailing' started by DrFunker, Jul 8, 2015.
  1. Jul 8, 2015 at 4:05 AM
    DrFunker
    DrFunker [OP] Well-Known Member
  2. Jul 10, 2015 at 6:03 AM
    VermontTaco
    VermontTaco Well-Known Member
    Vermont
    2015 DCSB TRD Sport Silver
    Weather Techs Mats front and rear, Wet Okole seat covers, BakFlip Fibermax tonneau cover, Power Pop N' Lock, Flyzeye interior lights, Scangauge 2, IMMRYO Rearview mirror bracket, upgraded Homelink, temperature gauge, and compass rear view mirror, Matt Geko bed lights, OEM bed mat, Beerad's Antidark engine lights, interior LED lights, TRD SEMA 17" Wheels in gunmetal gray, LT265/70/17 BFG KO2 Load Range C, and center console/glove compartment organizers.
    I have been using the Nanoskin Autoscrub sponge for a couple of years on both my vehicles with excellent results. To me it is much easier to use then clay and you get so many more uses out of the sponge than you would with traditional clay. Another benefit is that if you drop it on the ground you can just rinse it out without any worries where as clay you might have to throw it away. I highly recommend buying the Nanoskin lube that is recommended - it works better than any detail spray that I have used in the past.
  3. Jul 10, 2015 at 11:20 AM
    DrFunker
    Yeah, just used the AutoScrub sponge on two spots yesterday. It did a great job.
    Have you tried their Shock yet?
  4. Jul 11, 2015 at 9:09 AM
    Mr. Sparkle
    Mr. Sparkle Well-Known Member
    Bryan
    Long Island, NY
    Silver 09 TRD Sport
    Leer Cap Subfloor, water pump, marine battery, 45 gal water tank & plumbing to wash cars anywhere
    I've tried many clay substitutes over the years (speedy prep towel, nanoskin mitt, the item shown in this thread, opti-clay towel etc)
    It all really depends on the paint. They all work (as in they remove surface contamination like they are intended). However, on sensitive paints they will marr the paint. Sometimes badly. More noticeable on dark colored base coats. I've seen it a number of times that now as a strict rule unless client is paying for some type of paint correction work, no clay substitutes. We use the real stuff (usually clay magic blue). Otherwise the decon potentially can leave a mess.
    To be clear, these are great products and time savers in many cases but use with caution. Try a small area first, dry, and inspect in direct sun before going forward with the entire vehicle
    DrFunker[OP] likes this.
  5. Jul 11, 2015 at 9:33 AM
    DrFunker
    Great advice. Thanks Mr.S. Much appreciated.
  6. Jul 11, 2015 at 11:24 PM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    Thank you! I've been kicking around the idea of a clay substitute but I think I will stick to the trusty clay bar.
  7. Jul 12, 2015 at 11:00 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    yep my only fear of clay subs are marring...even tho i have white, i still hate them swirls lol
  8. Jul 16, 2015 at 6:22 AM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    So I have never used clay before. However I have been looking into the Nano skin products just so that I could save some time doing this my first time. I have a 2013 super white that has not been waxed yet. Any suggestions on how to proceed?
  9. Jul 18, 2015 at 2:47 AM
    DrFunker
    @andyzx6r
    Check this out:
    https://www.tacomaworld.com/threads/official-ask-a-detailer-thread.8957/
    I think it may give you a better idea of what is out there.
    Nanoskin is just one product in a sea of many different products (and techniques).
    Hope that helps ya.
