Narrower, and more arch leaf springs on a second gen tacoma 4wd
Discussion in 'Suspension' started by Pinoiako916, Apr 5, 2014.
  1. Apr 5, 2014 at 1:38 PM
    Pinoiako916
    Pinoiako916 [OP] Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Is it possible to put in narrower 66-77 Ford Bronco leaf springs on a second gen Tacoma? I am not into the whole thing on flexing, but I am looking for narrower leafs so that I can cut more frame behind the rear leaf spring shackles to improve approach/departure angles.
    The narrower Ford Bronco leafs are 21-24 inch from center to front shackle and 21-24 inch from center to rear shackle.
    Also, I understand that the stock second gen leafs are 27.5 inch from both center to rear and front shackles.
    What is your advice on this? Can this be done.
