Nasty Defroster smell
Discussion in '1st Gen. Tacomas (1995-2004)' started by Choco Taco, Oct 19, 2008.
  1. Oct 19, 2008 at 12:11 PM
    Choco Taco
    Choco Taco [OP] Sprayin' Paint like Its my Job
    South Dakota
    01 D-CAB SR5
    2" Lift 265/75/16' MT's Homemade Prerunner Bar
    hey, i've noticed this since i boutgh my pickup. everytimei turn the defroster on my cab smells like a combination of dirt and ass. but only when its on defrost. Any Ideas?
  2. Oct 19, 2008 at 12:23 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    In cabin air filter???
    Then again it's only on defrost, idk.
  3. Oct 19, 2008 at 12:26 PM
    Choco Taco
    South Dakota
    01 D-CAB SR5
    ...and its a first gen
  4. Oct 19, 2008 at 12:28 PM
    TacoNut
    Adam
    Denver, Co
    ahh sorry... should probably read next time. :D
  5. Oct 19, 2008 at 3:45 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    any smell in max a/c? and is the temp blend door in warm or cold? and if you move the temp blend door does the smell change?
  6. Oct 19, 2008 at 3:48 PM
    Choco Taco
    South Dakota
    01 D-CAB SR5
    never have too nasty of a smell when i turn on the A/C just a little blast of usual AC smell when i first kick it on. with the defroster its always stinkin'
  7. Oct 19, 2008 at 4:12 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    What i've done was run the A/C full on with the FRESH AIR button on then have a friend spray an odor neutralizer into the air intake vents at the back of the hood as you switch through each setting-vent/floor/defrost that way EVERYTHING gets a dose:)
  8. Oct 19, 2008 at 4:14 PM
    Choco Taco
    South Dakota
    01 D-CAB SR5
    i'll give it a shot
  9. Oct 19, 2008 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This is a good idea!
    Also, anytime the defroster is on, so is the AC. Moisture can accumulate and go "bad", or stale. Run the Fresh air, As Ridgerunner stated, with the AC "Off" (any setting other than "Defrost") for a min. before you shut down the truck. :)
  10. Oct 19, 2008 at 4:24 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Ozium works well to get that moldy sock smell out of vents.
  11. Oct 19, 2008 at 8:23 PM
    Mr.Fahrenheit
    very true, agree 100%. but also would recommend checking your a/c drain just to much sure its not plugged or blocked.......if blocked could cause the moisture to stay in the system and cause that usual a/c stench. just an idea:)
  12. Oct 19, 2008 at 8:38 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    i had that smell in my 1st and 2nd gen tacoma i like the odor neutralizer idea to!
  13. Oct 20, 2008 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Valid idea, but if its blocked, it would leak water on the floor of the cab. :)
  14. Oct 20, 2008 at 4:55 PM
    Mr.Fahrenheit
    true, true.
  15. Oct 20, 2008 at 11:45 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    My truck stinks when I run the windshield wiper fluid with the air on. The air by itself doesn't smell (all of them are fine, defrost/ac/regular), but once i turn on the fluid, ohhh man it smells. Is there a way to "febreeze" that?
    Yes. Hijackin the thread.
