Nathan's Long Travel Build
Discussion in '1st Gen. Builds (1995-2004)' started by Conman117, Apr 29, 2012.
  1. Sep 15, 2013 at 12:53 PM
    #681
    Conman117
    Conman117 [OP] AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    I have varying degrees of happiness.
    Like right now, with the truck torn apart and just sitting in the shop, its no fun. Once I have everything and start building it'll get better and when its done, well, thats party time.
  2. Sep 15, 2013 at 12:54 PM
    #682
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    So while its all stripped down inside, is there anything I should be doing thats way easier with no interior?
    I'll most likely be doing a bunch of sound dampening, and maybe new speakers.
  3. Sep 15, 2013 at 1:34 PM
    #683
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Sound deaden everything! Make sure everything is nice and sealed as well!
  4. Sep 15, 2013 at 1:37 PM
    #684
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Any recommendations on what stuff to get?
    And I plan on doing the floors, walls, doors. Anyone ever do the roof?
    I'll see how much its going to cost and that might determine how much I do:rolleyes:
    EDIT: Dynamat of some sort. Xtreme maybe?
  5. Sep 15, 2013 at 1:46 PM
    #685
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Rammat is one the most cost effective stuff I've found. :cool:
  6. Sep 15, 2013 at 1:49 PM
    #686
    PLC721
    Patrick
    Chandler, Az
    Layer of that with a layer of ensolite foam and you'll be crusing as quiet as a caddy
  7. Sep 15, 2013 at 1:53 PM
    #687
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    I'll go look these up. Thanks!
  8. Sep 15, 2013 at 10:30 PM
    #688
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    How much of a difference did it make? Worth tearing it apart?? If so I might add that too the never ending list of mods to do....
  9. Sep 15, 2013 at 11:06 PM
    #689
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Its different for everyone I think. I had probably an inch of play in my steering wheel, almost scary on the freeway. Doing this deffinetly helped, but there is still a little bit of play at the connection to the rack. But it took the really sloppy play out. You can reach under the steering column and grab the lower part of the slip joint then shake the wheel back and forth to see how much play is in yours.
  10. Sep 16, 2013 at 10:31 PM
    #690
    FBGW01
    Kaleb
    East Mesa AZ
    check my build
    alright ill check it out in the morning! thanks!:thumbsup:
  11. Sep 16, 2013 at 10:44 PM
    #691
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Here's the write up I followed. Read the post to know whats going on, then as stated in the first post, there's a slightly easier way around post 43-45 (dont remember) to take apart the steering.
  12. Sep 16, 2013 at 10:57 PM
    #692
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    awesome build. just read this entire thread.
  13. Sep 16, 2013 at 11:09 PM
    #693
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Thanks man!
  14. Sep 26, 2013 at 6:42 PM
    #694
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    So while the interior is apart, I went ahead and got these.
    BE11596C-B108-4083-84F8-D8213C1DB573-740_aa3e391547b20216aecc5ab6c1abd447d6c0f266.jpg
    And yes, this will get installed someday, just like everything else. :eek:
    The bender finally showed up so I'll get that setup this weekend, then I'm going to lock myself in the shop for a while
  15. Sep 26, 2013 at 6:48 PM
    #695
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Hard to go wrong with JL!
    I've got a 500 slash amp in my tundra and two w3 10's and I'll warn you...it's more amp than speaker. Good bass songs and it'll start to smell like sharpie!
  16. Sep 26, 2013 at 6:52 PM
    #696
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    Yeah, I was deciding between the 250 and the 500, so I just went with 500 :rolleyes:
    The speakers should clean up songs a lot too I hope.
  17. Sep 26, 2013 at 7:01 PM
    #697
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yeah the 500 is solid man. Seriously, you'll have to tune it down a little bit. The subs will not keep up.
  18. Sep 26, 2013 at 7:05 PM
    #698
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    You guys are making me want to upgrade my audio... Haha
  19. Sep 26, 2013 at 7:12 PM
    #699
    Conman117
    Nathan
    BC, Canada
    98 Brap-coma
    I'll keep that in mind :thumbsup: I really don't want to break things.
    Also the warranty is void if you go over 300 watts with the subs. Don't know how they tell though...
    Well my rear wall panels are off so I figured I'd do the rear speakers... And the subs will be harder to do later, should do those too... And the wiring will be nicer now... And down the rabbit hole we go
  20. Sep 26, 2013 at 7:13 PM
    #700
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    When the voice coils melt (the sharpie smell)...that's when it's void. :D
