Natural gas/propane smell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, Jun 26, 2016.
  1. Jun 26, 2016 at 7:15 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    recently I have been smelling propane type smell inside my truck. It is not continuous. I smell it for a minute then nothing for 30 mins or so. I thought maybe it was only when I was going up a hill but I have smelled it at other times too.
    Any ideas??
  2. Jun 26, 2016 at 7:42 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Catalytic converter?
    DustStorm4x4 likes this.
  3. Jun 26, 2016 at 7:44 PM
    anthony250f
    Anthony
    San Diego, CA
    That's what I was thinking too. How would you even test that? It has a magnaflow cat I think
  4. Jun 26, 2016 at 7:51 PM
    FirstGen Jer
    Jeromey
    Pulled this from another thread I was reading on...
    I tested my Cat with an infrared thermometer. From what I understand, while driving a vehicle that issufficiently warmed up, a healthy catalytic converter's OUTLET should read much hotter than its INLET. For example, on a healthy Cat you might see the temperature readings of exhaust going IN at 400 degrees and come out the other side at 550 degrees (these are EXAMPLE numbers only!!!) So I go for a 30 minute drive, then pull over and take some temp readings. On mine, the temp readings on the outlet side are consistently the same or lower than the inlet....which is one indication there is a problem with the cat.
    My next Cat check included hooking my real time scanner up and observing the O2 Bank1 Sensor1 and Bank1 Sensor2 voltage output while driving. Here's my scanner:
    http://www.amazon.com/gp/product/B005NLQAHS?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
    It's my understanding that the inlet O2 sensor should fluctuate quite a bit (between 0 and 1) as its checking fuel trim, whereas the outlet sensor should be more steady. In my case, they both fluctuated a lot...almost in sync.
    After doing my own DIY tests, I decided to take the vehicle in. I dropped it off at my mechanic this afternoon and simply told him my check engine light was on. Nothing more. An hour later, he called and said my cat needs to be replaced and suggested I consider doing the O2 sensors as well. I told them to do the Cat only, as the sensors are a piece of cake to replace
    Brie and DustStorm4x4 like this.
  5. Aug 21, 2016 at 5:31 PM
    anthony250f
    Anthony
    San Diego, CA
    Believe I fixed the problem. I had routed the diff breather in the cab
  6. Aug 21, 2016 at 8:31 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lol, yeah that'd do it.
  7. Aug 22, 2016 at 10:11 AM
    Indy
    Indy Master of all I survey.
    Well, I guess if you had to plug 1 end of the engine into the cab you chose the right one.
    anthony250f[OP] likes this.
  8. Aug 22, 2016 at 3:06 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    just curious why you would plumb the diff breather into the cab??
    Brie and anthony250f[OP] like this.
  9. Aug 22, 2016 at 4:15 PM
    anthony250f
    Anthony
    San Diego, CA
    I don't have a gas cap area and everything is "open" and I was being paranoid about water and mud and shit lol.
  10. Aug 22, 2016 at 4:18 PM
    cruiserguy
    Elijah
    SEKS
    No biggie, but you did get a chuckle out of me:rofl:
  11. Aug 22, 2016 at 4:20 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The breather just needs to be higher than any water crossing level. I put mine in the storage cubby, it was too easy! See my signature link for the thread on how to do the breather mod...
    Brie likes this.
  12. Aug 23, 2016 at 12:44 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I can understand being paranoid I feel the same way about women and sex so avoided it so far .
    A few more years and I should be safe
    CrustyTaco and Brie like this.
  13. Aug 23, 2016 at 4:11 AM
    Indy
    Just chain them together and route it towards the top of the engine compt. If you're real paranoid loop the end back down, or terminate it in your air intake.
    I can't imagine the kind of hell smelling grear oil all the time must be. I HATE that smell.
    digitaLbraVo likes this.
  14. Aug 23, 2016 at 5:09 AM
    cruiserguy
    Elijah
    SEKS
    Gear oil = man perfume
    Brie likes this.
  15. Aug 23, 2016 at 11:58 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I don`t think it smells anything like the chemical added to propane .
    Gear oil has it`s own smell one never forgets
    Brie and digitaLbraVo like this.
  16. Aug 23, 2016 at 12:00 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    :rofl:
    :bananadead:
    Brie likes this.
  17. Aug 24, 2016 at 3:24 AM
    Indy
    You don't date much do you...? :laugh:
  18. Aug 24, 2016 at 3:45 AM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    What the? LMAO
    Brie likes this.
  19. Aug 24, 2016 at 4:35 AM
    cruiserguy
    Elijah
    SEKS
    Oh is that my problem??? I always thought it was the unique 'vocabulary' that wrenching has taught me!
    I thought gear oil attracted gals like 'sh!t attracts flies'! The things you can learn on this forum.... Now I know, and knowing is half the battle. Thanks TW!
    Brie likes this.
  20. Aug 24, 2016 at 4:36 AM
    dmharvey79
    Dennis
    Northern Virginia
    OP, just a heads up...don't do that if you decide to upgrade your exhaust.
    jackn7 and Brie like this.
