Nav radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yamchee, Mar 13, 2018.
  1. Mar 13, 2018 at 2:03 PM
    Yamchee
    Yamchee [OP] Member
    2014 tacoma prerunner
    Lifted with 20" rims
    I need a radio navi for my 2014 tacoma non Jbl who can help me out
  2. Mar 13, 2018 at 6:30 PM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    Start checking out wrecking yards, picked mine up at one here in Canada for less then what they wanted on flea bay. 2014 to 2015 models fit and just plug into the wiring harness plus the GPS antenna is already in the shark fin and is for some reason plugged into the stock radio, white wire.
    Just make sure the micro card is still there as some yards pull them and sell them separately.
  3. Mar 13, 2018 at 6:48 PM
    Yamchee
    Yamchee [OP] Member
    Can you send the link i am here in Virginia so i dont know what is that is my 1st time own in a toyota tacoma
  4. Mar 14, 2018 at 3:32 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Search Google for:
    Toyota Navigation 57092
    eBay and others sites are asking $1,400+.
    Good Luck and Welcome to TW!
  5. Mar 14, 2018 at 3:34 AM
    Yamchee
    Yamchee [OP] Member
    Thanks brother for the info snd thanks gor the welcome greetings
  6. Mar 14, 2018 at 3:50 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    If you find a 57092 and you need a map card you can find those by searching:
    86271-OE185
    Or
    86271-35015
    Seems to be same part but has two part numbers.
  7. Mar 14, 2018 at 4:04 AM
    Yamchee
    Yamchee [OP] Member
    Dammmnnn brother thanks gor the info wha do you recommend to go with the etune unit or go aftermarket unit
  8. Mar 14, 2018 at 4:13 AM
    bear263
    bear263 Well-Known Member
    Florida
    2013 PreRunner TRD SP
    LED interior lights. Steering wheel mod. New radio. Amp, speakers and sub woofer.
  9. Mar 14, 2018 at 7:49 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I like the factory look of the OEM Navi and that it was plug and play. It does not have Apple Car Play but does have Pandora which works really well with my iPhone. Going after market gets you more options so deciding is a personal preference.
