Navigation calibration for tire change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Puddle_Jumper, Sep 26, 2018.
  1. Sep 26, 2018 at 6:16 AM
    Puddle_Jumper
    Puddle_Jumper [OP] Well-Known Member
    Bruce County Ontario Canada
    2017' Tacoma TRD Off-road DCSB
    Bilstien 2/1 level kit with 5100’s front (top setting) and 5160’s in the rear Ecgs bushing Prinsu cab rack Bestop Cali raised ditch lights Rago fab bed stiffeners Rssw heritage wheels with 32” ko2’s Westin bed mat Pro grille and tail lights Led dome, map and licence plate lights
    Has anyone tried this to see if it keeps the odometer true aswell when changing tire size.
    I wonder how big a tire this would compensate for.
    Im sure 265/75-16 will be fine as its only 3% larger than the stock size.
    kgilly likes this.
  2. Sep 26, 2018 at 6:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    The difference between old and new tires is minuscule.
    In other words the normal difference between a new tire and one on the tread bars.
    Pretty sure it won't do diddly for an actual + sizing.
    shakerhood likes this.
  3. Sep 26, 2018 at 6:36 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    There's one way to find out...
    Puddle_Jumper[OP] likes this.
  4. Sep 26, 2018 at 6:50 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    planning on going up to 265/75-16's in about a month or so as I have almost 33k on the originals and will replace before winter hunting time..woohoo
  5. Sep 26, 2018 at 9:13 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Pretty sure it can only calculate for stock tire sizes.
    tonered likes this.
  6. Sep 26, 2018 at 9:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would like to know this since I am thinking of going to 265/75R17 when the time comes.
    I have to say that the Taco speedos agree with GPS better than anything else that I have driven. Given the relationship, it would be an easy calibration for the Taco to do. It is not like there is a mechanical speed drive connection anywhere on the truck.
    I calc'ed it a long time ago that new versus worn tires (17in motorcycle tires with 10/32in of tread), there was a 3% change in actual versus indicated speeds. Getting within 3% should be a no-brainer for the truck?
    shakerhood[QUOTED] likes this.
  7. Sep 26, 2018 at 9:59 AM
    17SandTaco
    17SandTaco Well-Known Member
    Conifer, CO
    2016 Tacoma OR
    What's the procedure for this, is this a setting in the Nav menu?
  8. Sep 26, 2018 at 10:13 AM
    Clipper16
    Clipper16 Well-Known Member
    Gil
    Tennessee
    2018 TRD Sport ACLB Intense White Tech and Pro
    Theoretically it makes sense. The GPS knows how far you’ve driven. Comparing that to the odometer it probably generates a correction factor for wheel revolution vs circumference.
    The GPS on my iPad mini is accurate enough to put me right on the center line of a runway.
    Page 254 of the 2018 TECHNOLOGY OWNERS MANUAL.
    tonered likes this.
  9. Sep 26, 2018 at 4:34 PM
    Puddle_Jumper
    The tires i have now are 1” larger than the stock size and have a circumference 3% larger
    The radar traps at my work said i was going slower then what the spedo showed with stock size
    I went to 265-75-16 and now the radars are bang on with the dash
