NAVISURFER II gets a hefty overhaul ($400 Dbl Din Computer)
Discussion in 'Audio & Video' started by BadBrains, Feb 22, 2011.
  1. Feb 22, 2011 at 7:45 PM
    BadBrains
    BadBrains [OP] Spreading the Aloha
    Wes
    Dothan, AL
    '07 Tacoma TRD OR, '00 Integra GS-R
    King, Dakar, 285 MT/R's, Aluminum this and that.
  2. Feb 22, 2011 at 7:50 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Tempting
  3. Feb 25, 2011 at 5:03 PM
    BLACKnBLUE
    BLACKnBLUE Well-Known Member
    Iain
    Ellensburg, WA (Kittitas County)
    07 TRD SR5 with ARB Front Bumper
    ARB front winch bar, 3" lift, blacked out badges, blacked out headlights, Custom Steel Rear Bumper Mod, and Leer 100XQ
    It "looks" too big to fit in the dash for some reason... overkill?
  4. Feb 26, 2011 at 2:40 PM
    DevL
    DevL Well-Known Member
    The hard drive would be toast in under 3 months with vibrations from off-road driving... never use a conventional hard drive with moving parts for off-road use.
  5. Feb 27, 2011 at 6:57 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Honolulu, HI
    17 Inferno TRD-OR DCSB 4x4
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    DevL, Not true...until I upgraded to a SSD last year, my regular HDD was in my trunk for almost 5 years (and it still works...it's not it my vehicle anymore). For 4 of those years, it was sitting less than a foot away from my subwoofer. I initially put it there as an experiment and ended up leaving the whole PC there to see what it could withstand...much to my surprise, I never had a problem with the vibrations.
    The thing that will determine how good or bad this product will be is the software. They need to make sure it is very easy to use and making sure that it is touchscreen friendly. They need to make it as easy to use as a normal radio/nav unit and not like a normal computer with tiny fonts.
  6. Feb 28, 2011 at 5:56 AM
    beatle
    beatle Well-Known Member
    Springfield, VA
    98 3.4l SR5 TRD
    Agree on this. If you look at the demo video on their website, you see a guy operating the applications with a stylus, tapping through lots of menus. There's no way I'd want to go through an interface like this just to listen to music or access the GPS. When it comes to car interfaces, simple is even more important.
  7. Feb 28, 2011 at 6:49 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Make sure you look into the specs on these. These units seem to be built for European consumption, and the radio/TV standards are different then here in the US. Also note that these appear to be no-mech units, i.e., no DVD/CD drive. Depending on your use, this may be good or bad.
  8. Feb 28, 2011 at 8:21 AM
    BadBrains
    Wes
    Dothan, AL
    Guess you'd have to use a USB Optical drive to load stuff.
    If you really wanted an SSD, you could probable swap it out.
    I'd like to see some modders load up Android on it or some other simple touch-screen enabled OS.
  9. Feb 28, 2011 at 9:04 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Looks like a good idea that needs to evolve and refine more. I'll wait a few years and see.
  10. Feb 28, 2011 at 10:09 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    question I have is how the hell do you mount the sucker?? there's no mounting holes or anything - what are we supposed to do, drill our own holes for it?? That will go well with a motherboard sitting right underneath it. If they expect us to install it with a cage, hell no... that would definately have vibration problems (offroad use or not).
    I like the looks and thought of it, and the price is not that bad either... and honestly I wouldn't care too much about the radio anyways - I'd just tether my iPhone to it and stream the radio through Ootunes or use Pandora, and for the times I'm not in cell coverage (which is too often - thanks AT&T) there's always my mp3 selection
  11. Feb 28, 2011 at 2:30 PM
    DevL
    What kind of a vehicle? A sub woofer vibration is not a problem... offroad jolts and vibrations are much worse becasue they are so much larger. Ive killed several hard drives with offroad use and know several people who killed the hard drives in their Jeeps.
