ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. May 15, 2014 at 8:50 PM
    #181
    Tacobilly
    Tacobilly New Member
    Bill
    Next to TJ
    4x4 TRD
    None.....YET!
    Does the DTRL issues have anything to do with the position of your parking brake? Just a thought.....
  2. May 16, 2014 at 6:31 AM
    #182
    bajatoy
    bajatoy Well-Known Member
    Peoria AZ
    Magnetic TRD Off-Road
    Not for me. I was driving and tried both the headlight and fog light switch in all positions. Mine is functioning completely normal now. This mod is is 100% fine and a huge thanks to th op! My guess is when you pull the relay, the computer drops connection and it just takes a few key cycles or a specific amount of time for the DTRL's to reset. I think only 3 of us have had this issue and all 3 were back to normal in less than a day!
  3. May 16, 2014 at 8:19 AM
    #183
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah never had an issue since i did this mod, fogs come on any time and all other lights function as they should.
  4. May 17, 2014 at 8:50 PM
    #184
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    OK...update on my issues with the mod.
    Tacobilly, you nailed it, dude.
    Indeed, my issues were related to the parking brake and the fact that the DTRL apparently does not come on if the parking brake is engaged initially. All my initial testing was done parked in the garage which is why the DTRLs never came on (despite my assertion that they were on and went off, it's near certain that was not the case). So, today, (while still in the stock setup) I pulled the truck out of the garage and turned on the DTRLs after releasing the parking brake. No blown fuse as I incorrectly presumed. Then I redid the mod, released the parking brake, and everything worked as intended.
    Lesson here for anyone doing this mod...when testing, make sure you test with the parking brake off. Run the light switch sequence and all lights should work as before. Except now the fog lights should work independent of any of the other lights.
    Thanks, ND4, for coming up with this flavor of this fog lamp mod. And thanks to several others on this thread whose input helped me troubleshoot.
  5. May 17, 2014 at 10:09 PM
    #185
    nd4spdbh
    SoCal
    ^Glad it was that easy!
  6. May 20, 2014 at 10:19 AM
    #186
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    This mod works. Just one hiccup though. When I went to put back in the inverter relay it was a tight fit with the male connector for the fog light anytime mod. I ended up applying a bit to much force, which wasn't that much, and snapped the prong on the inverter relay. It didn't snap off, it just pushed in severing the electrical connection to the relay.
    It being a holiday monday in Canada and no autoparts places were open, I was fubar'd. I decided to raid my 2014 3/4 ton Dodge for a relay. Turns out Dodge put a relay in for air suspension, even though my truck doesn't have that. Stole that relay, put it in the Tacoma, and now everything is fine. Well, other than there being a dodge part in my Tacoma lol.
  7. Jun 8, 2014 at 8:18 AM
    #187
    2wdTRD
    2wdTRD Well-Known Member
    Alabama
    Prerunner TRD Sport
    TRD Exhaust,
    Did this yesterday and I love it, thanks OP!
  8. Jun 15, 2014 at 9:59 PM
    #188
    Halftunn50
    Halftunn50 Member
    Orange Co., NY
    Tacoma V6 Short Bed
    URD MAF Sensor Calibrator
    2007 DC 6Speed Manual: So I did the mod. It was easy....Fogs work by the independent hit of the fog button in the cab even if the Key is not on or in the ignition....cool. I can get Full HBeams with Fogs if I want. But depending on the sequence of when I hit the FOG Button or turn the rotating headlight switch...I get different results....strange.
    Sometimes the first thing I do is put the Parking lights on then hit the Fogs...and both the fogs and Low Beams come on at the same time...even though the LOW BEAM switch hasn't been turned...HUH?!?! I was expecting to see FOGs, DTRLs and side markers on, not the LOW beams.
    But if I change the sequence and turn the Fogs on first, then the Parking Lights, the LB's won't come on like I would expect when I switch up to LB's....then other times I switch right up to LB or HB's from the start, then hit the Fog switch and nothing...they don't fire...only LB's or HB's like stock. ????????????????????????
    By the way: I have the relay (interior fuse panel) for the Large Amber Yellows lights, on permanently, by taking a tiny piece of folded electrical tape to hold the contacts together...giving me DTRL's
    and I did the mod EXACTLY the way ND4 showed us....and by taking power from the Large Grey AC Relay.
    Anyone know if this effects the rest of the lights??
    ......so weird
  9. Jun 16, 2014 at 8:34 AM
    #189
    nd4spdbh
    SoCal
    You definitely did it wrong then.... the fogs should NOT be able to come on without ignition turned on as the 12v source to power the relay that you pull off the AC relay is a switched on ignition 12v.
  10. Jun 16, 2014 at 8:40 AM
    #190
    Manwithoutaplan
    ID
  11. Jun 16, 2014 at 11:48 AM
    #191
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you have trouble getting the connector plugged in with the other one buy a "fuse tap" for an ATC fuse and land your wire with the 10 amp A/C fuse it will go off with the key. I did not do mine because I did not want to have to turn off the fog lights during the day maybe one day I'll tap into the parking light circuit to run the relay.
  12. Jun 16, 2014 at 12:41 PM
    #192
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I think what he did wrong is hes back feeding the circuit i did this when i did mine. I pulled power of one of the other relays and pushed it into side of the fog light relay without using the jumpers and it caused all kinds of weird things. You need to make sure you have all the jumpers right or you could back feed the lighting circuit. This is were having a voltage meter helped.
  13. Jun 16, 2014 at 1:13 PM
    #193
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Nice will try to attempt this.
  14. Jun 19, 2014 at 2:50 PM
    #194
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    done mine today works like a charm thanks
  15. Jun 20, 2014 at 2:02 PM
    #195
    Therealwinshady
    Therealwinshady Well-Known Member
    Shannon
    Portland(west linn), Or
    2011 DCLB TRD Sport
    5100's and 885's, AAL, fog light mod, map light mod, viper 5706, OR tow hook, inverter anytime mod, Firestone air bags, devil horns, hood scoop riged light bar, 32 inch bumper light bar,
    Did mine today on a 2011, easy as butter
  16. Jun 20, 2014 at 2:33 PM
    #196
    melissa0031
    melissa0031 Just enough knowledge to be dangerous
    melissa
    Northern Greenville South Carolina
    2015 silver metallic 4Runner trail edition
    Traded my taco for a 2015 4Runner trail edition..let the fun begin...
    Did mine and it works perfectly!! Thanks op!
  17. Jun 20, 2014 at 4:07 PM
    #197
    nd4spdbh
    SoCal
    glad i could help some more people out!
  18. Jun 25, 2014 at 7:43 PM
    #198
    907Yoda
    907Yoda currently trying to get lost...
    Rapid City SD
    2015 TRD Off Road
    13% Tinted, 5000k HID headlights and fogs, Wet Okole Seat Covers, Weathertech wind deflectors, 13" Shorty antenna, PowerAid throttle body spacer, XTP Intake Manafold Spacer, Magnaflow cat back exhaust, grillcraft grill
    Will be attempting the mod this weekend. Awesome write up!
  19. Jun 28, 2014 at 10:34 PM
    #199
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Care to share. Trying to do this mod with the xb fogs
  20. Jun 28, 2014 at 11:01 PM
    #200
    tacodane
    Dane
    Let me know trying to do it as well
