ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Jul 11, 2014 at 8:31 AM
    #221
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Sounds like a bad connection somewhere... more than likely the switched on 12v ignition source (brown wire in OP)
  2. Jul 11, 2014 at 8:35 AM
    #222
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    Well I would but I didn't tap that relay .zuja8yta_91b2ae5cb7a414bc49a394da9944b0f334c77b9c.jpg. As you can see I tapped in a spot that is always hot so my fogs can come on when ever I'd want them to. All I can say if it doesn't work on the relay your tapping find a spot like I did and just use that for the power
  3. Jul 11, 2014 at 8:53 AM
    #223
    RileyLAFD
    RileyLAFD Well-Known Member
    Riley
    City of Angels
    '14 DCLB Magnetic Grey
    I guess I've got to start this very soon....
    Alright when I have some more time I'll give it a try.
  4. Jul 11, 2014 at 8:58 AM
    #224
    tacodane
    Dane
    I failed twice trying this mod. Just make sure everything. Is clamped down right and give it another try
  5. Jul 11, 2014 at 9:21 AM
    #225
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Great mod! Very easy to do just have to take your time and make sure your connections are good!
  6. Jul 11, 2014 at 9:26 AM
    #226
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    If you have a meter or a cheep tester to check for voltage on the brown wire after you have tapped into the source that your using. With the ignition on you should have 12volts then connect it to the fog light relay. If its not the power source then it has to be a bad connection at one of the other jumpers you made.
  7. Jul 11, 2014 at 9:27 AM
    #227
    RileyLAFD
    Riley
    City of Angels
    That's the plan the next time I have some free time. Thanks!!!
  8. Jul 11, 2014 at 12:44 PM
    #228
    907Yoda
    907Yoda currently trying to get lost...
    Rapid City SD
    2015 TRD Off Road
    13% Tinted, 5000k HID headlights and fogs, Wet Okole Seat Covers, Weathertech wind deflectors, 13" Shorty antenna, PowerAid throttle body spacer, XTP Intake Manafold Spacer, Magnaflow cat back exhaust, grillcraft grill
    Worked well! it took me more time to heat shrink the connectors than to actually hook it all up. I would definitely recommend doing this
  9. Jul 11, 2014 at 12:49 PM
    #229
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    I did it this way as well couldn't find any relay that i really wanted to mess with that wasn't vital so chose a constant 12 in an empty space.. only problem is you have to remember to turn them off of you'll run your battery dead
  10. Jul 11, 2014 at 12:57 PM
    #230
    tacodane
    Dane
    Ya but you can't forget. I mean I only use the at or around night time so I will always see them on and just turn them off.
  11. Jul 12, 2014 at 3:36 AM
    #231
    sayboo4
    sayboo4 Active Member
    Boo
    Eastern North Carolina
    2012 TRD Sport 4x4 DCLB
    My Build: http://www.tacomaworld.com/forum/2nd-gen-tacomas/316703-my-build-2012-dclb-white-4wd-sport.html
    Same problem here......
    Gonna do this today:
  12. Jul 13, 2014 at 5:37 PM
    #232
    Grakyn
    Grakyn Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    Just finished. Works well and it's amazingly easy. Great job OP!
  13. Jul 13, 2014 at 5:59 PM
    #233
    RileyLAFD
    Riley
    City of Angels
    How'd it go?
  14. Jul 15, 2014 at 11:20 AM
    #234
    MCM78LC
    MCM78LC Well-Known Member
    Saint Paul, MN
    2021 Toyota Land Cruiser
  15. Jul 16, 2014 at 10:27 PM
    #235
    Grakyn
    Kyle
    2013 DCLB TRD Sport
    I spoke too soon. Worked for a couple days, now I have the same issue. Multimeter time tomorrow.
  16. Jul 17, 2014 at 8:46 AM
    #236
    nd4spdbh
    SoCal
    yeah you got a bad connection somewhere... gotta crimp those connectors good and make sure the male connector that goes into the socket for the AC relay is actually INSIDE of the female spade connector in the socket.
    Mine has been 100% problem free and exactly the same since i did this write up and pictures, havnt touched it.
  17. Jul 17, 2014 at 9:07 AM
    #237
    Grakyn
    Kyle
    2013 DCLB TRD Sport
    I pulled over last night and did a side of the road check. All connections seemed quite secure. Like I said though, I'll get in there with a multimeter and figure out what the issue is pretty quick. Not worried.
  18. Jul 17, 2014 at 9:08 AM
    #238
    RileyLAFD
    Riley
    City of Angels
    Having the same issue...
  19. Jul 17, 2014 at 9:12 AM
    #239
    Grakyn
    Kyle
    2013 DCLB TRD Sport
    I performed this mod with the fog light wiring powering two Rigid Dually D2s, so maybe that's part of the issue...
  20. Jul 17, 2014 at 11:34 AM
    #240
    tacodane
    Dane
    I thought my mod went bad to but I was flipping the wrong switch :cool:
