ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Sep 9, 2014 at 8:05 PM
    #281
    Tatonka777
    Tatonka777 Active Member
    Marty
    Washington State
    '21 TRD Sport ordered
    So I just finished the mod, off of the TAIL TOWING relay. Works like a champ. Now I can use the fogs with the running lights, low beam & high beam headlights.
    So you will see that I ran the trigger wire (red wire) down through the large fuse box, through the factory wire loom and up into the small fuse box. The small fuse box will detach from the large one and the bottom can be removed to run the wires. I then made my jumpers and fed them down through the small box and back up another slot to attach to the Fog Relay. I made for less wire having to be crammed into the small box. I already had the 14ga black and red wire so I just color-coded with heat shrink. I will say the only downside is that due to the other relay that butts up to the TAIL TOWING relay I was unable to use a male spade connector and had to tin the wire and feed it in with the relay leg. Not ideal but it works. Should see my neighbors looks as I am rewiring a brand new truck....priceless.
    I give all credit to nd4spdbh, as he had the original Mod and guided me to the TAIL TOWING relay to the trigger power. Thanks.
  2. Sep 9, 2014 at 9:44 PM
    #282
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    awesome glad it all worked out!
  3. Sep 10, 2014 at 10:12 AM
    #283
    Lou Slink
    Lou Slink I like daags...
    Catskill, NY
    2013 TRD OR DCSB
    OME 886's, Total Chaos UCA's, Dakar's, BFG KO2's on Method Race Mesh Wheels, Bunch of All-Pro Goodies, Warn Zeon 10S Winch
    Sub'd. I'll be playing with this tonight! (the fog light mod, that is...)
  4. Sep 12, 2014 at 6:00 AM
    #284
    Tatonka777
    Marty
    Washington State
    Added pics
  5. Sep 23, 2014 at 10:31 AM
    #285
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    Is there any way to trigger the fog light so it comes on with parking light. I want to be able to turn on parking light and have fogs on than they will be on with low and hi beam also. Thanks
  6. Sep 23, 2014 at 5:29 PM
    #286
    Mmchugh
    Mmchugh Well-Known Member
    Connecticut
    2014 DCSB SR 4x4
    Anytime foglight mod, plastidipped grill emblem, Weathertech floor liners, Python 4206 remote start
    Read this thread.
  7. Sep 23, 2014 at 5:43 PM
    #287
    nd4spdbh
    SoCal
    im sure there is a way, let me do some digging in the wiring diagrams
    edit - actually just a couple posts up
    http://www.tacomaworld.com/forum/2n...no-bending-100-reversible-15.html#post9149633
    tap into the towing tail relay and your good (granted if you have it)
  8. Sep 24, 2014 at 3:53 AM
    #288
    Mmchugh
    Connecticut
    2014 DCSB SR 4x4
    This entire thread is about the "Fog Light Anytime Mod" it allows fog lights anytime.
  9. Sep 24, 2014 at 1:54 PM
    #289
    Tatonka777
    Marty
    Washington State
    Look at my post with the pics. Thats how I did it.
  10. Sep 26, 2014 at 5:50 PM
    #290
    drop4205
    Windham, Maine
    14 TX Baja
    does tapping into the tow tail relay affect the light when a trailer is hooked up?
  11. Sep 27, 2014 at 1:52 PM
    #291
    PburghTaco32
    PburghTaco32 Well-Known Member
    Brennan
    Pittsburgh
    13 Sport
    Weathertech Liners, Ultragauge, Pop n' Lock PL5300
    so, had this hooked up for months. took it off to take it to get looked at for something else. hooked it back up, and blew fog light fuse, headlights don't work, inverter in the bed doesn't work, hvac doesn't work, clutch cancel switch does not work, abs light and traction control light is on. Any ideas????
  12. Sep 27, 2014 at 2:02 PM
    #292
    nd4spdbh
    SoCal
    Nope, not one bit, you are simply pulling probably 1/10th of an amp of power to switch on the relay for the fog lights
    You shorted something out, start checking all your fuses.
  13. Sep 27, 2014 at 2:08 PM
    #293
    PburghTaco32
    Brennan
    Pittsburgh
    13 Sport
    Pulled all the fuses under the hood, fog fuse was bad, didn't pull the ones in the cab yet...
  14. Sep 27, 2014 at 2:19 PM
    #294
    PburghTaco32
    Brennan
    Pittsburgh
    13 Sport
    Checked all the fuses in the can, the ign no. 2 was blown. Everything is good, thanks!
  15. Sep 27, 2014 at 2:19 PM
    #295
    PburghTaco32
    Brennan
    Pittsburgh
    13 Sport
  16. Sep 29, 2014 at 3:35 PM
    #296
    drop4205
    Windham, Maine
    14 TX Baja
    so you just tin the wire and make a 90 degree bend in it then flatten the end of it to fit into the relay slot?
  17. Sep 29, 2014 at 3:57 PM
    #297
    nd4spdbh
    SoCal
    if you cant fit it then yes.... If you bend the male spade in a Z shape then you could probably make it work in that tight spot.
  18. Oct 7, 2014 at 9:05 AM
    #298
    Swampeast
    Swampeast mud member
    Missouri
    2013 DC Off-Road
    Wet Okole TRD seat covers, SnugTop Super Sport, Bilsteins 5100 front 1.75, Bilstein 5100 rear, 1/2" Toytec AAL, Swaybar relocate kit, differential drop, ND4's fog light anytime, Relentless Fabrication brackets with Rigid Industries D2 with AirOnBoard center switch 923B, rear view mirror relocate bracket, N-Fab front light bar
    Completed this mod. Thanks for making this so easy with a great write up and method.
  19. Oct 8, 2014 at 7:01 PM
    #299
    Tatonka777
    Marty
    Washington State
    Pretty much how I did it.
  20. Oct 11, 2014 at 2:35 PM
    #300
    Jmcavene
    Jmcavene Wish I Had TRD OffRoad
    New England
    '14 Access Cab SR5 4x4
    Nd4 anytime foglights, WeatherTech digital fit floor mats, WeatherTech Side Window deflectors, WeatherTech Stone & Bug Deflector
    So I have a 2014 SR5 4x4 I have the little side panel with the two blue cube relays but not the big gray one (AC/DC)? The space where it should connect is there but it is not there in itself. So can I still make the switched connection there or does it mean I have to look else where. I have the wiring and crimp connectors. Will put them together tonight.
