ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. May 18, 2015 at 9:24 PM
    #441
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    I want to do this, but I'm not very good with wires.... :(
    patbegley likes this.
  2. May 20, 2015 at 8:47 AM
    #442
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    Thanks to ND4 & Justin, I finally got this mod to work! now to get some bright fog light bulbs!
  3. May 20, 2015 at 9:54 AM
    #443
    JB
    JB ....................
    Justin
    CA
    2015 Off Road DCSB
    ICON Stage 2, SCS Wheels, Toyo R/T's, 6-Speed
    Sweet!!
  4. May 23, 2015 at 9:26 PM
    #444
    MCM78LC
    MCM78LC Well-Known Member
    Saint Paul, MN
    2021 Toyota Land Cruiser
  5. May 24, 2015 at 4:37 PM
    #445
    Nowayhilljay
    Nowayhilljay Member
    Ontario
    Supercharged...
    Just finished this mod on my truck. Love it!!!!
    So easy to do. Can't wait to get my LED fogs in to go with my retrofits. Thanks OP!
  6. May 30, 2015 at 7:47 PM
    #446
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    results of the work, again thanks to Justin and ND4
    JB likes this.
  7. May 30, 2015 at 8:01 PM
    #447
    JB
    Justin
    CA
    2015 Off Road DCSB
    By the way, @YanE30M3 made me this just because I sent him some photos of the procedure. image.jpg So, help him out and he makes a cool image of your truck!!
    YanE30M3 likes this.
  8. May 31, 2015 at 1:33 PM
    #448
    scrubby510
    scrubby510 Well-Known Member
    Nor Cal
    S/C '12 DCSB OFF-ROAD & ‘24 DCSB OFF-ROAD
    TRD s/c, DT shorties, 6" Pro Comp Stage 2, 5034 Rockwells on 35s, skid plate, tint, Morimoto D2S retrofitted headlights, 6k HID, Switchback DTRL, Walbro 255 lph fuel pump, URD 2.85 pulley, URD MK3 catback exhaust, debadged, ND4's anytime foglight mod, 6" Alcans… ‘24 OR work in progress.
    Finally got around to doing this yesterday!!! So happy with how it turned out! Thank You!!
  9. May 31, 2015 at 3:26 PM
    #449
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    SWEEEET!!! glad it was easy for everyone to follow!
  10. May 31, 2015 at 4:43 PM
    #450
    Caliyota
    Caliyota Member
    San Diego, CA
    '14 DCSB SR5 4x4
  11. May 31, 2015 at 5:07 PM
    #451
    KSJ08
    KSJ08 Well-Known Member
    2015 White Access TRD Sport
    So what is everyone doing W/relay after this mod?? Letting lay in relay box?
  12. May 31, 2015 at 5:24 PM
    #452
    JB
    Justin
    CA
    2015 Off Road DCSB
    Yes, just trim the wires to a length that will allow the relay to lay in the box with the cover on it. Also, recommend using insulated connects which are not shown in my photo.
  13. May 31, 2015 at 6:09 PM
    #453
    nd4spdbh
    SoCal
    I did a couple wraps of electrical tape on mind so it wedges between the side of the box and another relay, Hasnt moved since i put it in place a long time ago.
  14. May 31, 2015 at 6:20 PM
    #454
    KSJ08
    Great will do this mod ! Thanks
  15. Jun 5, 2015 at 5:50 PM
    #455
    Caliyota
    Caliyota Member
    San Diego, CA
    '14 DCSB SR5 4x4
    Just finished this mod. It's awesome to finally be able to have my fogs on with my brights!
    My 2014 SR5 doesn't have the inverter ( :( ), and I liked Tatonka's idea of running it through the stock wiring harness.
    (Sorry for the crappy cell phone pic. The sun was half on half off the two fuse boxes and produced a glare)
    I wanted to be able to pop the hood and not be able to tell anything had been done, so I ran the wire through the stock conduit and zip tied/taped it back up to factory appearance
    Ran the wire through the bottom of the auxillary fuse box
    Insulated connectors like many have suggested
    And there it is! Completely stealth, unless someone decides to open the fuse boxes :D
  16. Jun 5, 2015 at 6:00 PM
    #456
    nd4spdbh
    SoCal
    ^ Looks CLEAAAAN! i like it man, good job!
  17. Jun 6, 2015 at 11:22 AM
    #457
    KSJ08
    I did the mod like nd4spbh. Works as advertised. Had to trim the - blade down for the receptacle too wide.After I did it I read through the complete explanation :-0
    I was thinking of just rewiring the 12V input at the socket just run a jumper from the pwr relay that is used with the bent blade?
  18. Jun 6, 2015 at 12:24 PM
    #458
    BLaPointe
    BLaPointe Well-Known Member
    Brandon
    Fairbanks, AK
    15 TRD Off-Road, White
    I will be completing this at some point in the near future. In conjunction with insulated connectors, I will also use heat shrink tubing just as an added layer for stabilization of connections as well as giving it a nice clean look. What gauge wire are people using to complete this?
  19. Jun 6, 2015 at 4:48 PM
    #459
    Jtaoj0
    Jtaoj0 Well-Known Member
    Add another successful install. 2015 dcsb trd or. Thought the switch off was lame as soon as I drove the truck home. OP you did a fantastic job of figuring this out and documenting. Many thanks.
  20. Jun 6, 2015 at 5:35 PM
    #460
    nd4spdbh
    SoCal
    I wouldnt go smaller than 16awg for the two main power wires. (big blades)
