ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Aug 23, 2015 at 11:06 AM
    #521
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ^Now that is clean!
  2. Aug 23, 2015 at 3:51 PM
    #522
    shuwtist
    shuwtist Enthusiast
    Northern Virginia
    2015 Tacoma TRD OR magnetic gray
    In development!
    Thanks to you!
  3. Aug 26, 2015 at 6:25 AM
    #523
    Voodoo Actual
    Voodoo Actual Well-Known Member
    2015 TRD Pro
  4. Aug 29, 2015 at 6:48 AM
    #524
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    How are you getting the bent brown male connecter to fit into the slot with the relay shown in the first picture with the grey box relay??
    Edit: I found the answer in some earlier posts. Great mod, worked like a charm! Thanks ND4!
  5. Aug 30, 2015 at 8:30 AM
    #525
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Pretty good camera. I could send the photos into the lab and check your criminal history. Not really, but I've seen worse prints submitted. Your bass thumb would give you up. Lol.
    Rattletrap66[QUOTED] likes this.
  6. Sep 3, 2015 at 2:26 PM
    #526
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rofl:
  7. Sep 28, 2015 at 3:26 PM
    #527
    nd4spdbh
    SoCal
    Just wanted to update this after someone pointed out i never stated WHICH hole the bent male pin of the brown wire went into down in the ACDC socket....
    Put it down into the spot where the red pin would go labeled in the attached picture.
    MrFixit420 likes this.
  8. Oct 1, 2015 at 4:49 PM
    #528
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
  9. Oct 3, 2015 at 9:36 AM
    #529
    Sinktip
    Sinktip Member
    Bothell, WA
    2015 TRD Pro
    Thanks to the OP. 15 min job. Works great.
  10. Oct 4, 2015 at 5:24 PM
    #530
    REDLINE35
    REDLINE35 New Member
    image.jpg Thanks to the OP for this great mod. Dremel was helpful to trim the blades for the green connections.
  11. Oct 4, 2015 at 9:09 PM
    #531
    YBLegal
    YBLegal Well-Known Member
  12. Oct 5, 2015 at 7:13 PM
    #532
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
  13. Oct 5, 2015 at 8:01 PM
    #533
    shuwtist
    shuwtist Enthusiast
    Northern Virginia
    In development!
    I removed the wire that went there and put it in a blank spot. It wasn't easy getting it out, but I am sure there is a technique to it. I pushed and shoved until it came out. Then I ran my splice wire up into the same spot with a female connector. I have since replaced that wire with one routed to the trailer light relay so the fogs work exactly like the rest of the lights.
  14. Oct 5, 2015 at 11:04 PM
    #534
    YotaMan
    YotaMan TTC #0091
    Austin, Texas
    2020 Tacoma TRD Pro 4x4
    De-Badge,UltraGauge,Westcott Designs fox lift, 18” fuel rebels, Nitto Ridge Grapplers, interior led lights.
    I did this mod on Sunday - and my push button on the dash for the outlet in the bed quit working - no longer lights up and am assuming the outlet in the bed isn't working either? Anyone else experiencing this problem? I have a 2015 TRD sport DCSB-4x4- the dogs work anytime though?? Not sure what happened.... Any thoughts?
  15. Oct 6, 2015 at 8:46 AM
    #535
    nd4spdbh
    SoCal
    its possible that you messed up the ACDC relay when you pushed it back down into the socket, pull it out and inspect it
  16. Oct 6, 2015 at 9:28 AM
    #536
    rjjencke
    Robbie
    Arizona
    My exact thoughts. My AC relay actually started to separate a little when I pulled it out which concerned me. However, my button still works.
  17. Oct 6, 2015 at 10:09 AM
    #537
    YotaMan
    YotaMan TTC #0091
    Austin, Texas
    Thanks guys, I'll inspect and see. Anyone an idea how much they cost if it is screwed up ( the ac relay )? Thanks
  18. Oct 6, 2015 at 10:13 AM
    #538
    rjjencke
    Robbie
    Arizona
    I believe someone in this thread said $16 if I recall correctly.
  19. Oct 6, 2015 at 10:16 AM
    #539
    YotaMan
    YotaMan TTC #0091
    Austin, Texas
    Ok , cool . I was waiting for someone to say " that's the expensive one" , lol thanks
  20. Oct 6, 2015 at 9:00 PM
    #540
    YotaMan
    YotaMan TTC #0091
    Austin, Texas
    Ok I pulled out the relay and what do ya know... The spade is crammed up into the relay! How did you get the 2 male conectors into the female ( lol ) ... I took a female spade that has a male made into it- bent the relay spade out to the side - plugged the female spade to the
    ( bent ) male of the relay and then used the single male that's made into the female I started with and pushed it into the fuse block.. And it worked...
