ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Apr 18, 2016 at 2:03 AM
    #601
    6uam671_tacoma
    6uam671_tacoma Well-Known Member
    SOCAL (LA/OC)
    08 SW TRD OR & 13 SSM TRD OR
    (08)12-15 Front-end conversion w/TRD Pro grill, Icon UCAs, 5100s w/OME 885, 1.5” Headstrong AAL, SCS Matte Black Ray10s mounted with Nitto 265/75/16 Ridge Grapplers (13) Ironman 4X4 UCAs, Bilstein 6112/5160, Headstrong AAL, SCS Matte Black w/Blaze Bronze lip Ray10s mounted with Nitto 285/70/17 Ridge Grapplers
  2. Apr 19, 2016 at 8:18 AM
    #602
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    I mean A LOT
    I would just ask for a dollar to help cover sending them. I'll send as many as you'd like up to 10. Thanks.
    BassAckwards and Norton like this.
  3. May 1, 2016 at 8:46 PM
    #603
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Completed this mod a few minutes ago. Thanks to @nd4spdbh (for the detailed write-up) and @GARSHA91 (for the piggyback connectors)!
  4. May 2, 2016 at 5:26 AM
    #604
    Rickhead
    Rickhead Active Member
    SW Washington
    2011 Tacoma TRD Sport
    Just completed this! Thank you! It is amazing that we have to go to such lengths just to gain control over the components of our own property. Next up, gain control of those pesky DRL's and chimes and beeps!
  5. May 2, 2016 at 7:55 AM
    #605
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Glad i could help out!
  6. May 11, 2016 at 7:20 PM
    #606
    GARSHA91
    Chicago
    I still have about 30-40 piggyback relays for anyone who wants to buy some. I'd just ask for a dollar or two to cover shipping. Thanks.
    Norton likes this.
  7. May 13, 2016 at 8:38 AM
    #607
    Mickeydog
    Mickeydog Well-Known Member
    Dave
    West Michigan
    2020 TRD Sport, Cement DCSB
    Pro wheels with 265-70-17 Goodyear UT. Pro skid. Pro tail lights. OEM tailgate power lock.
    Thanks ND4,
    Just did this mod today on my 2015 TRD OR.
    Works great and no codes.
    Much appreciated.
  8. Jul 10, 2016 at 10:59 AM
    #608
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    I modded my fog lights following this original post a few months ago and they worked perfectly, however, I just noticed the fog lights are no longer working with the fog switch on or off (with the ignition on).
    The AC/DC Converter switch lights up and I tested the outlet which works fine. So should I assume the fog light relay has gone bad??
    **Update: I confirmed the fog light fuse was blown, replaced it with a new one and it also blew as soon as I pressed the fog switch.
    Any ideas what could have changed causing the fuse to blow? I'm using LED fogs from Jumper. I also recently changed my license lights to LED.
  9. Jul 10, 2016 at 8:23 PM
    #609
    nd4spdbh
    SoCal
    Something is shorting out, Double check all your connections because if they are proper it will not blow fuses... mine has been in my truck untouched since i made this thread 2.5 years ago without issue.
    Norton likes this.
  10. Jul 10, 2016 at 8:30 PM
    #610
    Norton
    +1. I installed this mod a couple of months ago, and have had ZERO problems.
    GARSHA91 likes this.
  11. Jul 10, 2016 at 9:16 PM
    #611
    rjjencke
    Robbie
    Arizona
    That's what I was afraid of .. I'll undo everything and reinstall the mod and see if I have any luck. Can't go back to stock.. I love the anytime too much!
  12. Jul 11, 2016 at 6:00 AM
    #612
    GARSHA91
    Chicago
    If you need the piggy back ones let me know. If you ordered them already and need one or two more let me know too.
  13. Jul 11, 2016 at 12:52 PM
    #613
    rjjencke
    Robbie
    Arizona
    UPDATE: Resolved! Apparently the actual LED bulbs were touching the fog light housing causing a short. These bulbs have a metal casing. I reinstalled and then centered them in the housing and now I'm good to go. Hope this helps someone else.
  14. Jul 11, 2016 at 3:14 PM
    #614
    nd4spdbh
    SoCal
    And there we go! its usually something simple, luckily we have fuses on alot of things to make the failures not cause catastrophic damage.
    Lou Slink likes this.
  15. Jul 14, 2016 at 10:00 AM
    #615
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
    Just completed this mod, it's awesome and very easy using the OP. Thanks for a great write up. What if I wanted to cut my fog lights on and off at any time? Where would I grab my 12v?
  16. Jul 14, 2016 at 10:22 AM
    #616
    nd4spdbh
    SoCal
    at anytime meaning key out of the ignition turning them on?
    You could easily do it by grabbing another constant hot from the relay socket. Essentially you would make a 1 male to 2 female blade connector for use in the always hot 12v spot of the foglight relay, one of the females would go to the same blade as before (main power to the fogs) the other would go to the switch side of the relay (where the brown wire in my mod goes to)
  17. Jul 14, 2016 at 12:48 PM
    #617
    DuttonCD
    Alabama
    2018 TRD OR CEMENT
    No, just turn them on if I want them, or off if I don't. I had to use the EFI RELAY to grab my power because I don't have the converter relay. So my fog lights are on of my truck is on. I can't turn them off unless I go to hi-beam?
  18. Jul 14, 2016 at 3:22 PM
    #618
    caribe makaira
    Caribbean, Puerto Rico
    Suggest you place a 2~5 Amp fuse or a smaller gauge (22~18 Awg) where the white is...just saying...:bananadead:
  19. Jul 15, 2016 at 7:22 PM
    #619
    DuttonCD
    Alabama
    2018 TRD OR CEMENT
    So I noticed a problem tonight. I don't have fogs on low beam. Any other time I do, just not low beam headlights. Any ideas?
  20. Jul 15, 2016 at 7:50 PM
    #620
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    What did you hook up to in this mod? Which relay? Sounds like you hooked up to a relay that opens when on low beams.
