ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Jan 4, 2017 at 4:10 PM
    #681
    tgriff
    tgriff Well-Known Member
    Tim
    CT
    2014 TRD Sport 4x4 Black DCLB
    8.5" x 17" Fuel Hostage black wheels P265/65/R17 Toyo Open Country AT II tires Rigid Industries Dually LED pods on back bumper (Diffused pattern) Rigid Industries 10" SR2 amber LED light bar behind grille (Driving pattern) - Custom mount Magnaflow 18" performance muffler Magnaflow 4" resonator exhaust tip - Welded on 3M 35% tint on front windows Access Limited roll-up tonneau cover Uniden Bearcat 880 CB radio 4' Firestik Firefly CB antenna on Relentless Fab hood mount AVS vent visors Lamin-X amber fog light covers ND4's fog light anytime mod Ultragauge MX 1.3 mounted on dash - Custom mount Weathertech floor liners front & rear Access LED battery-powered bed light CravenSpeed stubby antenna OEM Bed Mat Bosch Icon windshield wipers Plasti-dipped front emblem Debadged TRD Sport bedside decals removed Mud flaps removed
    Just did the mod and it worked great! Thanks for this awesome thread @nd4spdbh !
  2. Jan 4, 2017 at 4:18 PM
    #682
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Glad to hear it worked out! Dont go draining your battery now!
    tgriff likes this.
  3. Jan 8, 2017 at 5:31 PM
    #683
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    If anyone needs piggy back terminals I still have about 15-20. I ask for a few dollars to cover shipping. That's it
  4. Feb 6, 2017 at 9:26 PM
    #684
    asmith02
    asmith02 Well-Known Member
    WA
    2015 Black DCSB
    This worked great no issues for me. 2015 TRD OR. Thank you for the great layout and doing the leg work on this.
  5. Feb 17, 2017 at 8:21 AM
    #685
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    DONE!! Easy peasy, lemon squeezey.
  6. Feb 18, 2017 at 7:08 PM
    #686
    Tikabear
    Tikabear Member
    Memphis, TN
    2010 White V6 Double Cab Prerunner TRD Sport
    Did this mod today. I got the truck used and I thought there was something wrong with the fog's when they didn't come on after I pressed the button. Broke out the owner's manual only to learn they only work when the headlights are on. I thought that was ridiculous so I'm really glad I found this mod. The fog light relay is in the large box on my 2010 so I had to run a wire to the small box where the AC relay is. It's the only thing in the small box. I used a black wire so it's really not noticable unless you are looking for it. Works great. Thanks!!
    Fastbilly5 likes this.
  7. Mar 5, 2017 at 8:49 AM
    #687
    TheFallGuy
    TheFallGuy Well-Known Member
    The Dog House
    2015 PRO
    Great write up ND4, worked like a champ!
  8. Mar 7, 2017 at 6:21 PM
    #688
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
  9. Mar 7, 2017 at 6:27 PM
    #689
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I don't suppose anyone sells the extensions pre-made, do they?
  10. Mar 7, 2017 at 7:09 PM
    #690
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    I did mine a bit different. Instead of the extension, I removed the factory wire from the bottom left pin, which is the one everyone bends. Piped in a new wire to it, through the wiring loom and back into the main electrical box on the other side. Plugged it into the factory wired seat heater, which I do not have but it is set up for in my 2015 TRD Off-road. Put an inline fuse between the relay and the constant 12V source.
    Result is anytime on or off, regardless of key position. Sucks if you forget and leave it on. Just another option!
  11. Jul 8, 2017 at 9:19 AM
    #691
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Great job on this mod....tagged for later reference.
  12. Jul 8, 2017 at 11:21 AM
    #692
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Where do the 2 wires go when you run them off the middle pin? Somewhat confused as I has a 2015 SR5 that came with fogs. looking to do a constant 12v as well so I can use them whenever. Thank you for this awesome write up
  13. Jul 10, 2017 at 3:17 PM
    #693
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Just finished this mod, 13 trdor 4x4, works like a champ. Now on with the led fogs install in the morning. Years ago my Dad and I were heading out to hunt, ran into fog even the low beams produced too much glare. Had amber fogs on a toggle switch, so turned off the headlights, and with only the fogs I could see well enough to proceed, but a little slower.
    Thanks for sharing this.
    I got the wrong connectors, so I used shrink tubing, works.
    http://imgur.com/U6PTDhU
  14. Jul 10, 2017 at 4:03 PM
    #694
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Did the mod. Works fine. My little sub-junction box only contained the FOG relay.
    It also contained a spot and wiring for the Air Pump Heater. I did not have this relay but am noticing that many others do. I robbed my 12v ignition on signal from this unused relay spot. disengaged the clips and swapped the pins for a super clean mod.
    My concern though is, I see a lot of folks have the Air pump heater relay. I drive a 2012, the year with the most reported Air Pump issues, obviously wondering if the relay is not something I should have and may avoid Air Pump issues that have been common on the 2012s? My quick search into the topic didn't turn up much useful info.
  15. Jul 10, 2017 at 5:17 PM
    #695
    nd4spdbh
    SoCal
    If your air pump didnt function properly you would be throwing a code for sure. Its possible it is in another spot in the main fuse box or you dont have the air pump (which for a 2012 im 99.99% sure you do)
  16. Jul 26, 2017 at 10:07 PM
    #696
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
  17. Aug 18, 2017 at 9:13 AM
    #697
    BudH
    BudH Member
    Craig
    Kingston Massachusetts
    '15 DCLB TRD Sport, black
  18. Aug 19, 2017 at 9:27 AM
    #698
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Does anyone have issues with fog lights not turning off automatically after leaving and locking vehicle?
    I can see myself forgetting when using fog lights as running lights.
    I'm wondering if there is an alternative for this?
    Edit: fog lights turn off auto now. Went back and redid all connection crimps and wiring. Works flawlessly.
  19. Sep 9, 2017 at 9:30 PM
    #699
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Another happy customer here. Took like 5 minutes extra cause some junk from my supercharger was in the way so I had to take one bolt out and swivel it up.
    ^arrow showing the box I need to access, circle showing the two bolts
    ^not as clean as some of y'all and took way longer cause I'm inept at electrical stuff
    ^BOOM, love it!
    This got me too, I thought something screwed up. They worked after I started the truck though. Do they normally only turn on while the truck is running?
  20. Sep 9, 2017 at 10:28 PM
    #700
    Dan H
    Dan H Wife thinks I'm having an affair with my Tacoma
    Daniel
    Glendale AZ
    2006 indigo ink PreRunner DCSB- 2012 Venza AWD
    ProComp Pro Runner shocks n struts Painted engine cover Fog anytime mod Cherrybomb muffler Bestop 3/16 tailgate plate and top cap Where do I begin with all the camo
    No pics of the wiring but did this today. It was easy but the only problem was my fog relay is in the main fuse box and my inverter was in the small box. Thank you for sharing this mod.20170909_162900.jpg
