ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Jan 21, 2014 at 11:54 PM
    #61
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
    Just did this on my 14' trd.. Worked like a charm.. Except something happened to my drl lights, they didn't turn on.. Might be cause it's night time.. :/ Gonna try it in the daytime and see if it'll work..
  2. Jan 22, 2014 at 7:36 AM
    #62
    Eric F
    Eric F Well-Known Member
    AZ
    2014 DC SB TRD-OR 4x4
    Anytime fog lights, U.S. Off Road-Winch Mount Bumper, diff breather, Doug Thorley mid pipe
    Did you set it to 'DRL'?
    E
  3. Jan 22, 2014 at 9:37 AM
    #63
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah this should have zero effect on the DRL's
  4. Jan 23, 2014 at 9:28 AM
    #64
    BigE
    Eddie
    PNW
    I did and weird thing happened.. but next morning in the day time everything worked perfectly... Gonna have to keep an eye on it.
    I know it shouldn't because I for sure didn't touch the drl's or any part of it. But Im gonna keep my eye on it.
  5. Jan 23, 2014 at 9:51 AM
    #65
    W Bishop
    W Bishop Stupid should be painful!
    Stone
    South Fulton Tn
    2013 Tacoma 4X4 Reg Cab
    ToyTec coil over kit, Sliver Coils, Bilstein 5100 front & rear, Light Racing SPC UCA. Painted to match Coils, OEM Tacoma 4 leaf pack, Undercover, AFE Pro Dry air filter, Painted grill surround, FJ Cruiser Trail 17" wheels, Rubber bed mat, fog lights and sliders.
    OP
    I don't have the small black box on my 13 Reg Cab. I like to have this box for my fog lights and maybe other things. Any ideal where one might find one of these? I don't want my relay expose to the elements.
    Nice write up. Just needs to warm up so I can get these wired.
    Thanks
  6. Jan 23, 2014 at 4:20 PM
    #66
    nd4spdbh
    SoCal
    The i4 is probably different as you don't have the air pump relay or ac relay thus the box is not needed. The fog light relay will be in the main box and you can do the exact same mod there but will have to use a different source for the brown wire power. Read the notes in the op
  7. Jan 23, 2014 at 4:40 PM
    #67
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    Just did this on my 2012 and love it. It took 5 minutes. I took a screen shot of you finial wiring on my phone and had it to reference to as I did it. My far the best free mod I have ever done.
  8. Jan 25, 2014 at 2:31 PM
    #68
    eaglesfn5402
    eaglesfn5402 Well-Known Member
    anybody know of a website where I can buy different color wire and these blade connectors? what gauge wire did you use OP? (I'm in Germany and the PX on base doesn't have any of this, and German blade connectors are different then the ones in your picture. I'm still google searching for a website no luck yet.)
  9. Jan 25, 2014 at 2:36 PM
    #69
    Duchateau
    Duchateau Livin' the dream...
    Oregon
    '16 DCSB TRD OR
    http://www.powerwerx.com has some pretty good stuff
  10. Jan 25, 2014 at 3:11 PM
    #70
    nd4spdbh
    SoCal
    one of the posts earlier on stated 16awg wire is what i used.
    Heres the connectors i used... not the greatest of quality but they get the job done.
    http://www.ebay.com/itm/Hot-100-Pcs...361?pt=LH_DefaultDomain_2&hash=item1e850ab151
    #70
  11. Jan 25, 2014 at 3:15 PM
    #71
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Nice!!!
  12. Jan 25, 2014 at 3:30 PM
    #72
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I have the same truck you do and I don't have that relay either. Under the cover it says 'Air Pump Htr', but the relay socket is empty.... check the underside of the cover.
    No DTRL? If you mean the headlights always being on, then no. My amber lights closest to the grille are always on though... I've always interpreted that as DTRL.
    **Edit** Check this thread about the pump... http://www.tacomaworld.com/forum/technical-chat/212846-air-pump-htr-what.html
  13. Jan 25, 2014 at 5:09 PM
    #73
    eaglesfn5402
    #73
  14. Jan 25, 2014 at 8:11 PM
    #74
    nd4spdbh
    SoCal
    the Air Pump Htr is the relay that powers the emmissions air pump found on the V6's (2013+ and possibly 2012+).. It simply injects clean air into the exhaust manifolds to aid the catalytic converters in their operation.
  15. Jan 31, 2014 at 4:20 AM
    #75
    NateB
    NateB Active Member
    Nate
    MidMo
    2019 TRD Sport
    Question: Is the brown wire bent blade going into the same slot as a blade from the relay? Or is that slot empty?
  16. Jan 31, 2014 at 9:20 AM
    #76
    Eric F
    AZ
    The blade goes just in front of the slot for the relay, you may want to put a little bit of a bend into the blade just to ensure good contact.
    E
  17. Jan 31, 2014 at 9:44 AM
    #77
    13SilverStreakTRD
    13SilverStreakTRD Insane but Functional
    Republic of Texas
    2013 DCSB TRD OR
    tinted windows, window visors, stubby antenna, wethertech floor liners, dented tailgate
  18. Jan 31, 2014 at 6:41 PM
    #78
    nd4spdbh
    SoCal
    It goes into the same female blade connector that that leg of the relay goes into... the way it is bent is to allow the relay to sit flat rather than bending the male blade right at the barrel part which would hold the relay up out of the socket ~ 1/8 of an inch.
  19. Feb 1, 2014 at 9:22 AM
    #79
    NateB
    NateB Active Member
    Nate
    MidMo
    2019 TRD Sport
    Mission Accomplished.
    Thanks a bunch ND4!
  20. Feb 1, 2014 at 10:47 AM
    #80
    nd4spdbh
    SoCal
    Not a problem glad my tinkerings on my truck could help someone out.
