ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Dec 3, 2020 at 12:32 PM
    #1001
    Muddinfun
    Muddinfun Well-Known Member
    I’m having 2nd thoughts about this concept. I’m not sure if the key in switch remains closed when the key is turned to on. My other idea of having it ding seems solid though.
  2. Dec 3, 2020 at 12:44 PM
    #1002
    caribe makaira
    Caribbean, Puerto Rico
    I can live with
    :rofl:
  3. Dec 3, 2020 at 12:55 PM
    #1003
    Muddinfun
    But it doesn’t accomplish anything. The dinger will not ding with the key out of the ignition and the fogs on. The diode wire needs to go to the green/black wire. Not the green yellow wire.
  4. Dec 3, 2020 at 1:05 PM
    #1004
    caribe makaira
    Read again...
    If door is closed, no ding...
  5. Dec 3, 2020 at 1:10 PM
    #1005
    Muddinfun
    I read it several times. I’m right and you’re wrong. The goal here is to make the dinger ding when the fog lights are on and the door is open. From the factory, the dinger only dings when key is in the ignition and the door is open. Your wiring does not tell the combination meter that the key is in the ignition.
  6. Dec 3, 2020 at 1:14 PM
    #1006
    caribe makaira
    And when the door is closed, does it ding? You stated the unlock wire was the tap, I say it's the door ajar wire to tap.
    Actually either would work, but easy access is the Driver's door.
    Remove the key, and ding continues would be much better. Also, when vehicle is ON, no ding, so parallel circuit would not be an issue...
  7. Dec 3, 2020 at 1:21 PM
    #1007
    Muddinfun
    The “unlock warning switch” is the switch that closes when you put the key in. The “door courtesy switch” tells the combination meter that the door is open. Both circuits must see ground for the dinger to ding.
  8. Dec 3, 2020 at 1:23 PM
    #1008
    caribe makaira
    When vehicle is OFF...yes. So tapping the unlock would turn off the door open light while vehicle is ON.
  9. Dec 3, 2020 at 1:37 PM
    #1009
    caribe makaira
  10. Dec 3, 2020 at 1:37 PM
    #1010
    Muddinfun
    You’ve missed the whole point of my idea. The point is to be able to turn on the fogs without the engine running to set up camp. The problem with this is you turn on the fogs and drive to work. By the time you get to work, it’s a beautiful sunny day. You forget the fogs are on. You come out of work and the battery’s dead. With my idea, you take the keys out, open the door and it dings. The keys are in your hand and you go, “Oh yeah, the fogs are on”.
  11. Dec 3, 2020 at 1:39 PM
    #1011
    caribe makaira
    Fogs ON anytime was never mentioned. It's the switch left on after vehicle is off...:burp:
  12. Dec 3, 2020 at 1:42 PM
    #1012
    Muddinfun
  13. Dec 3, 2020 at 1:48 PM
    #1013
    caribe makaira
  14. Dec 6, 2020 at 12:46 PM
    #1014
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    sorry for the delay. busy few days. Initially I had trouble because of the 'narrow' blade. I wasn't getting good contact and the fogs were inoperable. Then it got cold, and dark, and I decided to wait.
    Turns out I had left 'shoulders' on the blade and it wasn't recessing deeply enough. cleaned that up and it works a treat.
    On the power supply, I took @caribe makaira 's advice and simply used a braided wire, female on the fog relay and splayed wires into the 'batt charge' pin #2 (per the image). Lead was showing 13.4v constant with the key on. :thumbsup:
    I did get lazy in terms of running that lead out the bottom of the fuse box. Temps in the 20's meant neither my fingers nor the plastic felt like cooperating, so I threaded it nicely between the relays and out. You can see the wire here.
    And success. On and off with the button. Stalk is completely out of the equation. And it shuts off with the key.
    Wednesday it's supposed to hit 50, so the SS3's will go in at that time. Woot!!
    Thanks again Caribe and @nd4spdbh for the assist!
  15. Dec 8, 2020 at 3:54 PM
    #1015
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Soooo I was thinking.... tell me if I’m just being dumb...
    what if I use an add a fuse in the 10a radio fuse spot?? Would that work? I have enough room to do it and make it look good.
  16. Dec 8, 2020 at 4:02 PM
    #1016
    Muddinfun
    Both of the radio fuses are powered all the time. If you want fog lights even with the key off, that would work until you forget and leave them on and the battery goes dead. Then they won't work.
  17. Dec 8, 2020 at 4:12 PM
    #1017
    Toywoodsguy82
    Patrick
    Oregon
    Honestly my thought when I first went looking for this thread was to be able to use my fogs at anytime so I’m not real worried about leaving them on.
    my only other question is I have diode dynamic SS3 pro’s in selective yellow coming and was hoping this would still work with those
  18. Dec 8, 2020 at 4:38 PM
    #1018
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    If you don’t care about switched power.. see below and you can stay within the same box. Will work with any light on the fog circuit.
  19. Dec 8, 2020 at 4:39 PM
    #1019
    Toywoodsguy82
    Patrick
    Oregon
    2007 isn’t the same as you guys with 12-15’s
  20. Dec 8, 2020 at 4:44 PM
    #1020
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Sorry missed that. Why wouldn’t you want to use the battery charger relay then to have that switched power safety?
