ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Mar 16, 2024 at 5:35 PM
    #1101
    Devilfan
    Devilfan Well-Known Member
    ND4,
    Thank you for posting this this mod. I did it today on my 14 DC and it works great!
    TacoEspecial and herecomesace like this.
  2. Mar 18, 2024 at 6:24 PM
    #1102
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    Thanks for this post I redid mine today and this made it simple, and easy! I used a fuse box I added to mine for my power source of power for mine. IMG_3691.jpg
    TxStVanWilder and herecomesace like this.
  3. Mar 18, 2024 at 7:26 PM
    #1103
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I make great use of this mod every week, driving on the empty mountain highway in the dark, with my high beams on.
  4. Mar 19, 2024 at 8:33 AM
    #1104
    Devilfan
    Hey, I just noticed this today, but as soon as I started my truck, my dash board lights were all on without the headlights on. I'm not sure if it was like and and I just noticed, but is anyone else having this issue?
  5. Mar 19, 2024 at 8:47 AM
    #1105
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    if you're talking about the indicator lighting, normal operation
  6. Mar 19, 2024 at 8:54 AM
    #1106
    Devilfan
    No, the lights for speedometer, tachometer, and the temperature gauge all come on when the truck starts. Only way to turn them off is to shut the truck off
  7. Mar 19, 2024 at 12:59 PM
    #1107
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That’s not how my 2015 TRD OffRoad behaves.
    What is your left stalk set to (headlight switch) when this happens? If you take advantage of the Tacoma turning the headlights off when you open the door when the truck is off and leave it set to on or parking lights, the dash backlights will be on, as you experienced.
  8. Mar 19, 2024 at 1:03 PM
    #1108
    Devilfan
    It doesn't matter what position the stalk is in. If the ignition is on, the lights are on.
    Even if the headlight switch is completely off, the lights are on with the ignition.
  9. Mar 19, 2024 at 2:56 PM
    #1109
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Normal operation..
  10. Mar 19, 2024 at 4:16 PM
    #1110
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This would have nothing to do with the mod described here unless you have done it wrong.
    That stated, I believe dash lights are always on unless you dim them fully via the dimmer.
  11. Mar 19, 2024 at 4:28 PM
    #1111
    Devilfan
    Yeah, I think you guys are right. It's just something I never noticed before and it's operating the way it's supposed to.
  12. Oct 7, 2024 at 3:46 AM
    #1112
    Ruger68
    Ruger68 Member
    Massachusetts
    2015 Tacoma DCSB TRD Sport
    Don't tell my wife but.. 5100's, OME 887, 2" AAL, Bed LED lights, 32" Front LED, Seat Jackers
    Hey nd4spdbh, a big thank you for posting this Mod! I finally got around to installing the wiring this past weekend and it works just as it should. I was previously hesitant to do this as all the other instructions appear to call for bending the tab and I didn't really want to do that.
  13. Nov 22, 2024 at 10:00 AM
    #1113
    BigRed2513
    BigRed2513 Active Member
    Grant
    Whistler, B.C., Canada
    2014 TRD Sport DCLB Super White
    Does this mod allow you to have fogs on with DRL?
  14. Nov 22, 2024 at 10:54 AM
    #1114
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Anytime means anytime.
    BigRed2513[QUOTED] likes this.
  15. Nov 24, 2024 at 5:27 PM
    #1115
    number9
    number9 Member
    Thanks to all for the great info in this thread. I am going to do this particular method for my son's truck, so the fogs only come on with the headlights.
    I'm going to run a wire along the OEM wire loom from the small relay box to the main fuse box, indicated by the red line in the pic below.
    I've searched this thread and not been able to find mention of what wire size (gauge) to use, or mention of what kind of load the wire needs to carry. This short of a distnce, I would think 16awg would be more than plenty?
    The way I am understanding this, if correctly, is the "Pin 1" of the DIM relay (left side of the pic where OP is holding the green wire) is just the "12v+ signal" to fire the DIM relay, I assume by the headlight switch being switched to On. Is that correct? IF SO, then running a wire from DIM relay Pin1 to the Fog relay pin shown is just "12v+ signal" to fire the Fog relay, correct?
  16. Nov 25, 2024 at 8:18 AM
    #1116
    nd4spdbh
    SoCal
    Ah dont want to do a standard anytime mod, you just want the fogs to come on with headlights regardless of high or low. You could do exactly what you describe and it should function like you want (could also go to pin 3 of DIM, or 3 of HEAD as its all the same.
  17. Nov 25, 2024 at 1:28 PM
    #1117
    number9
    number9 Member
    Any concern with using 16awg wire?
  18. Nov 25, 2024 at 1:49 PM
    #1118
    nd4spdbh
    SoCal
    For the super short lengths of the main load (within the aux fuse box) 16awg is more than adequate. The run for the coil energizing 12v to the main fuse box could be crazy small as the current for that is minimal.
  19. Nov 25, 2024 at 3:51 PM
    #1119
    number9
    number9 Member
    Thanks for the confirmation :thumbsup:
    nd4spdbh[QUOTED][OP] likes this.
  20. Feb 10, 2025 at 9:32 AM
    #1120
    secondgear
    secondgear Well-Known Member
    Texas
    2014 Prerunner V6 DCSB Barcelona Red Metallic
    Thanks, OP for the detailed instructions. Getting ready to do the mod soon (ordered quick disconnect and piggyback connectors). A bit unsure how to trim the connector so that goes into the ac-dc relay to get it to fit but will try. Quick q - with this mod, will my fog lights come on intermittently when the truck is parked?
