ND4's Fog Light Anytime Mod... NO splicing, No Bending, 100% reversible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd4spdbh, Jan 4, 2014.
  1. Apr 27, 2014 at 5:07 PM
    #161
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Sounds like one of your crimp connections is bad or your male spade connectors are not making connection inside the fuse box
  2. May 2, 2014 at 4:30 PM
    #162
    bajatoy
    bajatoy Well-Known Member
    Peoria AZ
    Magnetic TRD Off-Road
    Just so you know you haven't lost your mind... I just did this to my 2013 Prerunner TRD Off-Road and same thing... everything works like it should EXCEPT my DRL's.... I can turn the fogs off and on at will, but no DRL's at all??? I think I will leave it as it is and see... maybe the module (BCM??) Needs to relearn??? :mad: :( :mad: :(
  3. May 2, 2014 at 6:56 PM
    #163
    nd4spdbh
    SoCal
    ^ no, what this mod does has NOTHING to do with DRL's if done properly.
    There are ZERO connections in common between the fog light, the switched ignition hot from the AC relay and the DRL's
  4. May 2, 2014 at 11:36 PM
    #164
    bajatoy
    Peoria AZ
    OH I totally understand that, yet it happened! I agree this has nothing to do with the mod, I just wonder if when pulling the relays the BCM resets something??
  5. May 3, 2014 at 3:38 AM
    #165
    sayboo4
    sayboo4 Active Member
    Boo
    Eastern North Carolina
    2012 TRD Sport 4x4 DCLB
    My Build: http://www.tacomaworld.com/forum/2nd-gen-tacomas/316703-my-build-2012-dclb-white-4wd-sport.html
    I thought the same thing. Bought new connectors, gonna redo it. Thanks!
  6. May 3, 2014 at 8:24 AM
    #166
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    Some of Chinese connectors are stamped and folded from dual thickness material and tend to dislike modification. Rather than cutting down 1/4" male spades and using (loose-fitting) 1/4" females on the parallel power end, get 3/16" (.188) connectors. Also check to insure you didn't knock something else loose in the fusebox. As ND4 pointed out, there is no wired connection between those two circuits.
    Goodluck.
  7. May 4, 2014 at 9:36 AM
    #167
    sayboo4
    Boo
    Will do. Thanks!
  8. May 11, 2014 at 12:55 PM
    #168
    markc6606
    markc6606 Well-Known Member
    SoFlo
    '13 Off-Road
    I did this mod yesterday,super easy. Took all of 25 minutes.Thanks OP! I do have one question. I opened up to double check all my connections after driving it for a day today when I got home from about a 30 minute trip. Everything was still good but I did notice that it seemed the fog relay was a little warm to the touch. Is this normal while the relay is closed? It very well could have been that way before the mod but obviously I never had a reason to check. Thanks
  9. May 11, 2014 at 2:09 PM
    #169
    nd4spdbh
    SoCal
    When a relay is in an operating position the electromagnet will heat up a lil... Pair that with the enclosed area that its in as well as under hood heat yeah I could see it getting warm, but it shouldnt be excessive.
  10. May 11, 2014 at 2:48 PM
    #170
    markc6606
    SoFlo
    '13 Off-Road
    Don't think it's excessive at all, just never noticed it 'cause there was never a need to. Thanks man. I'll check it now and then
  11. May 11, 2014 at 5:03 PM
    #171
    magnetic11
    magnetic11 Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
  12. May 11, 2014 at 6:41 PM
    #172
    Jwbfx4
    Jwbfx4 Active Member
    Bama
    14' dcsb trd
    Thanks completed this earlier today. Worked great.
  13. May 12, 2014 at 5:49 PM
    #173
    ArnieSea
    ArnieSea Well-Known Member
    Arnie
    Salish Sea, WA
    2016 Double Cab TRD Sport 4X4
    Blazing Blue, with full tech package, Tow Package, & Tonneau cover.
    I finally got around to doing this mod. And thank you Taco Larry for your version. It worked great for my V6 2014 SR5 DBCB. I didn't have the inverter circuit to tap into either and the "add a fuse" was the perfect solution.
    Great thread all around!
  14. May 12, 2014 at 5:52 PM
    #174
    nd4spdbh
    SoCal
    Glad everyone is having success.
    Those who have used the EFI relay, do your fogs come on at weird times at all?
  15. May 13, 2014 at 12:25 PM
    #175
    sayboo4
    Boo
    Yes. Mine come on whenever they want.
  16. May 13, 2014 at 1:59 PM
    #176
    nd4spdbh
    SoCal
    No what i mean is say if you leave the fog light switch on, and turn the ignition off. Do the fogs randomly come on at like 4 hours intervals (when you are pulling from the efi relay) or something like they did with the fog light any time mod that spliced into the green wire (i think it was that color).
  17. May 14, 2014 at 7:22 AM
    #177
    BXTACOMA
    BXTACOMA Well-Known Member
    Joe
    Virginia Beach
    05 Tacoma PreRunner SR5
    K&N Cold Air Intake, Borla CatBack Exhaust, JBA Ceramic Silver Coated Long Tube Headers. Pioneer Avic Z1 In dash Navigation HDD Radio, Boston Acoustic Speakers+Subs and Amp.
    I'm going to try this on my 05 taco when I get home
  18. May 14, 2014 at 4:31 PM
    #178
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    First, I want to say I appreciate the time and detail you put into this mod. I did mine today but ran into the same issue that at least two others have on this mod - the DTRLs failed. I triple-checked connections before firing it up. It appeared that the DTRLs were on initially when running through the test sequence, but somewhere along the line, they went out and didn't come back on.
    I disassembled the mod and went back to stock, but the DTRLs are not coming on. I'm thinking I blew a fuse, but haven't had time to troubleshoot that yet. I remembered that others had DTRL issues so I came back in to search here first.
    I don't mean to piss on this thread, because I like the solution. But my scientific bent forces me to report that this went haywire for me. I will troubleshoot and hopefully be able to report soon that I've located the source of the failure.
    Cheers.
  19. May 14, 2014 at 6:32 PM
    #179
    nd4spdbh
    SoCal
    its possible something got down in somewhere to short the DTRL's .. like stated this mod should have zero effect on the DTRL's as all they really share is the common ground and hot.
  20. May 15, 2014 at 4:20 AM
    #180
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
