neat splice
Discussion in 'Technical Chat' started by boatswain, Mar 7, 2011.
  1. Mar 7, 2011 at 11:07 AM
    boatswain
    boatswain [OP] Well-Known Member
    carl
    palmerton,PA.
    09 barcelona red , base
    heat up the plastic on a crimp connector. push the metal part out of the middle; I use a nail to do this. slide a piece of shrink tube over the wire. using the removed metal sleeve, crimp the wires together. slide the shrink tube over the splice and heat. I've already put two pieces of shrink tube on for a double seal. the second piece should be longer and the next size larger. I've never had any problems with anything done this way, and it seems to work really well on exposed wires that need repair. also looks pretty decent.
  2. Mar 7, 2011 at 11:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I can't remember where I found them, but I found a box of the metal connectors you're talking about. No shielding, so you can crimp them on and heat shrink over them like you're talking about. Very nice, neat way to make connections, put a little solder in the connection, heat shrink it and you've got a splice that will never come updone and looks nice and neat.
  3. Mar 7, 2011 at 11:30 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I have some of the crimp-on butt connectors that have heat shrink tubing on them already. Just crimp then heat up the ends to shrink for a water tight connection.
    I try to solder and heat shrink for most stuff though.
  4. Mar 7, 2011 at 11:34 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    I need pics to make sense of this.
  5. Mar 7, 2011 at 12:00 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  6. Mar 7, 2011 at 12:10 PM
    Pugga
    Massachusetts
    F-150 Mod
    Never heard of them before today but they seem like they'd be handy in a bind!
  7. Mar 7, 2011 at 1:17 PM
    Evil Monkey
    Robert
    Escondido, CA
    They rock. You can get the non-weatherproof ones at some walmarts where they sell crimps. They're more expensive but they're much better and you can reuse them.
  8. Mar 7, 2011 at 4:31 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  9. Mar 9, 2011 at 7:48 AM
    boatswain
    carl
    palmerton,PA.
    never saw the double layer shrink tube you mentioned. I'll look for it. sounds like that would really work good on trailer wiring etc. like I mentioned earlier, I never had a problem with anything I needed to splice, but this sounds even better.
  10. Mar 9, 2011 at 8:01 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Ya where would I find the double layer heat shrink tube? I like using heat shrink tube for wiring, but never seen that double layer. Thats sounds like something I would like.
  11. Mar 9, 2011 at 8:16 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  12. Mar 9, 2011 at 8:27 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Nothing wrong with crimp on connectors if they are crimped properly. every issue I have ever seen with crimp on connectors is because they were crimped incorrectly. Needles nose or pliers are not the right way. I prefer the ones with the glue coated heat shrink already on them. They are a little pricey but work really well. You can find them at most auto parts stores. In the military.... yes military... think fighter jets, everything was crimped. we used similar splices to the ones i mentioned from the autoparts store except the metal piece and glue sleeve were separate... so you would crimp on the metal part then slide the sleeve over and heat shrink.
    http://crimpsupply.com/connectors/butt-splices
  13. Mar 9, 2011 at 8:30 AM
    macgyver
    Brad
    Canton, GA
    I think it's like a Unicorn
  14. Mar 9, 2011 at 8:38 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I think your right. Probably what the horn is made of. :spy:
  15. Mar 9, 2011 at 9:08 AM
    PreRunnerSeth
    Apex, NC
  16. Mar 9, 2011 at 9:15 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
  17. Mar 9, 2011 at 9:31 AM
    PreRunnerSeth
    Apex, NC
    I cant think of any retail stores that would have it... I think Frys does... but not many people have access to a Frys.
  18. Mar 9, 2011 at 9:35 AM
    macgyver
    Brad
    Canton, GA
    Hmmm...I can see fry's from the parking lot at my work :D Maybe I will pick some up for future use.
  19. Mar 9, 2011 at 10:10 AM
    PreRunnerSeth
    Apex, NC
    Hahah... I think you guys have a Fry's Grocery store? We have Fry's Electronics.. :) a bit different.
    Edit: Wow... just looked... no shit.. you have Fry's electronics... Never knew it had spread to the East Coast.
  20. Mar 9, 2011 at 10:14 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Never heard of Frys so I guess I'm sol. Thanks for the info though.
